COUNTRTAZ
#1 Posted : Monday, May 31, 2010 10:00:59 AM(UTC)
COUNTRTAZ
Water Wont Shut Off Keeps On Filling Overflows
#2 Posted : Monday, May 31, 2010 10:17:45 AM(UTC)
Replacement parts for LA8860XWQO models | AppliancePartsPros.com
If you can stop the water by shutting the unit off or unplugging it then the problem is probably the water level switch, Item 12 in Section2.
If you have to shut the taps off then it is probably a sticking water valve, Item 18 in Section 2.
This switch is actually a pressure switch. It has a tube that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch's set point then the switch activates turning off the water and starting the agitate.
Possible problems.
1. Gunk blocking water from entering the tube. Remove the tube at the switch and blow into it to clear the plug.
2. Cracks or holes in the tube allowing the air to escape. Inspect the tube. Also check that it is tight on the switch, if not, cut off half an inch and re-seat it.
3. The switch is toast. Get a piece of tubing with the same internal diameter and attach this to the switch. Start a fill, then blow into the tube. You should be able to stop the water flow without blowing very hard.
If you cannot stop it the switch is toast.
Note: I am assuming that you can stop the water flow by unplugging or turning off the unit.
If the only way to stop it is to shut off the taps your water valve is shot.
Water wont shut off after lever is pushed and released (Refrigerator & Freezer Repair)
by Jgregg23 11/12/2019 5:37:04 PM(UTC)
Water wont shut off (Refrigerator & Freezer Repair)
by beedman173 8/11/2015 5:27:52 PM(UTC)
Ice maker water wont shut off (Refrigerator & Freezer Repair)
by Don Phillips 2/22/2012 10:46:15 AM(UTC)
Washer cold water wont shut off (Washer Repair)
by debhug 1/25/2011 2:44:04 PM(UTC)
Kenmore Elite-water wont shut off, now wont drain or spin (Washer Repair)
by dbigotis 5/12/2009 10:31:02 AM(UTC)
Kenmore Elite-water wont shut off, now wont drain (Washer Repair)
by dbigotis 5/12/2009 10:26:23 AM(UTC)
