Spins, empties water but won't agitate. Tub will turn CCW but not CW. Agitator will not turn. Does this sound like a locked transmission? Is replace only option? Is there a way to unlock transmission? Thanks.
Sounds very much like your transmission, particularly if the motor is trying to turn in agitate mode.
Given the age of your machine and the costs of parts I would suggest replacing it. Get a basic top loader and you should be set for many years.
Originally Posted by: sidfink43 Sounds very much like your transmission, particularly if the motor is trying to turn in agitate mode.
Given the age of your machine and the costs of parts I would suggest replacing it. Get a basic top loader and you should be set for many years. You are right and that's what I did! Thanks! :D
You are welcome, wish we could have given you a way to fix it, but sometimes you just gotta go with a new one.
Good luck.
