Discuss
Whirpool Duet Sport Won't Pump Out
 in
Washer Repair
Duet Sport won't pump out water. Whirpool won't tell me what Fault Code F-33 means. Someone elswhere
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirpool Duet Sport Won't Pump Out
  #1 (permalink)
Old 07-11-2008, 12:00 PM
Haynesnorm Haynesnorm is offline
Junior Member
Haynesnorm is on a distinguished road
Default Whirpool Duet Sport Won't Pump Out
Model Number: WFW8300SW01   Brand: Whirlpool   Age: 1 - 5 years
Duet Sport won't pump out water. Whirpool won't tell me what Fault Code F-33 means. Someone elswhere said same as Kitchenaid "Leak" code.
Episode started with too sudzy F-21 code. I hung discharge hose higher in standpipe thinking that being too far down in "P-Trap" drain water was part of problem.
Have sponged out as much water as possible and tried over and over but doesn't work. Thing just humms a little and does nothing.
Anything else I can do B4 paying repair man? Is this thing a Pc. of junk in general? Worked fine when it worked but....
Seems like all washers and dryers are extremely crapily built am I wrong?
Related Models
Whirlpool WFW8300SW02 Automatic Washer
Whirlpool WFW8300SW03 Automatic Washer
Whirlpool WFW8300SW1 Automatic Washer
Whirlpool WFW8400TB00 Automatic Washer
Whirlpool WFW8400TW00 Automatic Washer
Whirlpool WFW8400TW01 Automatic Washer
Whirlpool WFW8410SW0 Automatic Washer
Whirlpool WFW8410SW01 Automatic Washer
Whirlpool WFW8500SR0 Automatic Washer
Whirlpool WFW8500SR01 Automatic Washer
Whirlpool WFW8500SR02 Automatic Washer
Whirlpool WFW9200SQ00 Automatic Washer
Whirlpool WFW9200SQ01 Automatic Washer
Whirlpool WFW9200SQ02 Automatic Washer
Whirlpool WFW9200SQ10 Automatic Washer
Whirlpool WFW9200SQA10 Automatic Washer
Whirlpool WFW9200SQA11 Automatic Washer
Whirlpool WFW9400SB00 Automatic Washer
Whirlpool WFW9400SB01 Automatic Washer
Whirlpool WFW9400SBA10 Automatic Washer
Whirlpool WFW9400ST00 Automatic Washer
Whirlpool WFW9400ST01 Automatic Washer
Whirlpool WFW9400STA10 Automatic Washer
Whirlpool WFW9400SU00 Automatic Washer
Whirlpool WFW9400SU01 Automatic Washer
Whirlpool WFW9400SW00 Automatic Washer
Whirlpool WFW9400SW01 Automatic Washer
Whirlpool WFW9400SWA10 Automatic Washer
Whirlpool WFW9400SZ00 Automatic Washer
Whirlpool WFW9400SZ01 Automatic Washer
Whirlpool WFW9400SZA10 Automatic Washer
Whirlpool WFW9600TA00 Automatic Washer
Whirlpool WFW9600TB00 Automatic Washer
Whirlpool WFW9600TC00 Automatic Washer
Whirlpool WFW9600TU00 Automatic Washer
Whirlpool WFW9600TW00 Automatic Washer
Whirlpool WFW9600TZ00 Automatic Washer
Amana WG1010.000 Commercial Microwaves
Amana WG1010.010 Commercial Microwaves
Amana WG1010.200 Commercial Microwaves
Amana WG1021.000 Commercial Microwaves
Amana WG1021.200 Commercial Microwaves
Amana WG1065.000 Commercial Microwaves
Amana WG1120.500 Commercial Microwaves
Amana WG1120.600 Commercial Microwaves
Amana WG1121.000 Commercial Microwaves
Amana WG1165.000 Commercial Microwaves
Amana WG1165.700 Commercial Microwaves
Amana WG1166.500 Commercial Microwaves
Jenn-Air WG200 Walloven - Cont Clean Gas
Jenn-Air WG206 Walloven - Cont Clean Gas
Jenn-Air WG24000B Walloven - Std Gas
Jenn-Air WG24000W Walloven - Std Gas
Jenn-Air WG30100B Walloven - S/c Gas
Jenn-Air WG30100W Walloven - S/c Gas
Amana WG445.1 Commercial Microwaves
Amana WG445.2 Commercial Microwaves
Whirlpool WGD5100SQ0 29" Gas Dryer
Whirlpool WGD5200TQ0 29" Gas Dryer
Whirlpool WGD5300SQ0 29"gas Dryer
Whirlpool WGD5300ST0 29"gas Dryer
Whirlpool WGD5310SQ0 29"gas Dryer
Whirlpool WGD5320SQ0 29"gas Dryer
Whirlpool WGD5321SQ0 29"gas Dryer
Whirlpool WGD5500SQ0 29"gas Dryer
Whirlpool WGD5500ST0 29"gas Dryer
Whirlpool WGD5520SQ0 29" Gas Dryer
Whirlpool WGD5521SQ0 29"gas Dryer
Whirlpool WGD5530SQ0 29"gas Dryer
Whirlpool WGD5540SQ0 29"gas Dryer
Whirlpool WGD5540ST0 29"gas Dryer
Whirlpool WGD5550SQ0 29" Gas Dryer
Whirlpool WGD5550ST0 29" Gas Dryer
Whirlpool WGD5560SQ0 29" Gas Dryer
Whirlpool WGD5600SQ0 29" Gas Dryer
Whirlpool WGD5600ST0 29" Gas Dryer
Whirlpool WGD5700SW0 29" Gas Dryer
Whirlpool WGD5790SQ0 29" Gas Dryer
Whirlpool WGD5790ST0 29" Gas Dryer
Whirlpool WGD5800SG0 29"gas Dryer
Whirlpool WGD5800SW0 29"gas Dryer
Whirlpool WGD5810SW0 29"gas Dryer
Whirlpool WGD5820SW0 29"gas Dryer
Whirlpool WGD5821SW0 29"gas Dryer
Whirlpool WGD5830SW0 29"gas Dryer
Whirlpool WGD5840SG0 29"gas Dryer
Whirlpool WGD5840SW0 29"gas Dryer
Whirlpool WGD5850SG0 29"gas Dryer
Whirlpool WGD5850SW0 29"gas Dryer
Whirlpool WGD5856SG0 29"gas Dryer
Whirlpool WGD5860SW0 29"gas Dryer
Whirlpool WGD5900SB0 29" Gas Dryer
Whirlpool WGD5900SW0 29" Gas Dryer
Whirlpool WGD6200SW0 29"gas Dryer
Whirlpool WGD6200SW1 29" Gas Dryer
Whirlpool WGD6400SB0 29"gas Dryer
Whirlpool WGD6400SB1 29"gas Dryer
Whirlpool WGD6400SG0 29"gas Dryer
Whirlpool WGD6400SG1 29"gas Dryer
Whirlpool WGD6400SW0 29"gas Dryer
Whirlpool WGD6400SW1 29"gas Dryer
Whirlpool WGD8300SB0 27" Gas Dryer
Whirlpool WGD8300SB1 27" Gas Dryer
Whirlpool WGD8300SW0 27" Gas Dryer
Whirlpool WGD8300SW1 27" Gas Dryer
Whirlpool WGD8410SW0 27"gas Dryer
Whirlpool WGD8410SW1 27" Gas Dryer
Whirlpool WGD8500SR0 27"gas Dryer
Whirlpool WGD8500SR1 27" Gas Dryer
Whirlpool WGD9200SQ0 Gas Dryer
Whirlpool WGD9400SB0 Gas Dryer
Whirlpool WGD9400ST0 Gas Dryer
Whirlpool WGD9400SU0 Gas Dryer
Whirlpool WGD9400SW0 Gas Dryer
Whirlpool WGD9400SZ0 Gas Dryer
Whirlpool WGD9500TC0 Gas Dryer
Whirlpool WGD9500TU0 Gas Dryer
Whirlpool WGD9500TW0 Gas Dryer
Whirlpool WGD9600SU0 Gas Dryer
Whirlpool WGD9600TA0 27" Gas Dryer
  #2 (permalink)
Old 07-11-2008, 03:28 PM
Junior Member
Default Fixed It!
OK - turns out pump is much easier to access than I thought. Took front panel off & low/behold a "service manual" taped to it! Code F-33 is check pump. Pump filter had 3 huge pcs. of sleeping bag string sucked all way inside pump. Code F-21 means "slow drain" which could be too much suds or in my case check pump.
This was a no brainer repair. Hardest part is getting water out of machine first. Use a cup, sponge, syphon hose etc. Then use a plastic paint tray under pump filter and unscrew it just enough to fill tray then dump out. Only takes about 4 times. Sooper easy.
  #3 (permalink)
Old 08-09-2009, 07:35 PM
casey2313 casey2313 is offline
Junior Member
casey2313 is on a distinguished road
Default whirlpool F21 and F33
Thank you! Our whirlpool duet washing machine kept showing F21 and F33 error codes because it wasn't draining. All the error codes are hidden inside the bottom panel. We unscrewed the panel, twisted the trap open, drained it and found a small plastic bag stuck in the pump area.
  #4 (permalink)
Old 09-03-2009, 07:56 PM
ezfix1234 ezfix1234 is offline
Junior Member
ezfix1234 is on a distinguished road
Smile Whirlpool Duet WFW8300SW03 F1 CODE
I had the same problem with my Whirlpool Duet today and was able to figure out the problem for $0.00. I should preface this without any help from the Whirlpool hot line, which were no help at all and rude at times on the phone.
Enough complaining...The problem you have is do to the design of the washing machine to allow items that were left in pockets to get down into the pump and pump filter chamber. The pump is located in the bottom, front, right hand side of the machine. I unplugged the machine first, then removed the back panel, removed the two hoses on the pump which you will want to have plenty of towels around for, then I loosened but did not remove the two screws in the bottom of the machine that give the pinch to the rubber base of the pump, then slide the pump slightly and it will pop out. Unplug the electrical connector to allow the pump to come all the way out the back.
There is a large hand tightened cap on the front of the large chamber in front of the pump that collects all the garbage left in your pockets. Get all this stuff out. Also you can separate the pump from the filter hosing and make sure there isn't anything like paper clips ect. in the pump blades. This was the problem I had. I pull the following items out of the filter chamber.
$1.13 in change, that included three quarters, 3 DS gameboy sticks, 6 paper clips, 4 hair clips one of which was also in the pump blades, a ring, and allot of hair/lint. Well the service Tech. I call said the repair would be around $350. if they need to replace the control board but I guess in the long run I ended up making or at least finding money in the process. Hope this helps other people out there with the same problem. I should also say that Whirlpool has the service manual taped to the inside bottom front of the machine. This has all the codes and possible fix actions for each problem. I guess they figured the homeowner was more likely to misplace these and the service Tech. would need them and find them when the machine was turn apart for service.
  #5 (permalink)
Old 09-04-2009, 09:23 AM
tiny2nz tiny2nz is offline
Junior Member
tiny2nz is on a distinguished road
Default Easy Fix... Whirlpool Duet sport washer
@ezfix1234 - Your post did help my husband and I fix the washer... since we were coming up on labor day weekend I knew the "warranty" people wouldn't be out until next week.... Well following you simple advice. We removed 3 hex head screws in front and accessed the drain clean out. Wow... .50 cents, (4 dimes, 1 nickle, 5 pennies) a couple bobby pins, sewing needles (odd), couple paper clips, and a lot of lint and pillow stuffing....! Needless to say I think the washer is working again. Wow Whirlpool made this a ingenious design both for the do it yourself fixer and the make some money repair guys...! My fix cost me nothing... repairs would have been much more.
Thanks Again to everyone on their posts.
  #6 (permalink)
Old 12-07-2009, 06:57 AM
feves feves is offline
Junior Member
feves is on a distinguished road
Default F01, F21, & F33 codes
The prior posts were right on the money. However, cleaning mine didn't fully cure but I've not been able to separate the motor from the filter yet. Pump works initially in cycle but in later stages gets really hot around the windings above the pump motor.
The paint tray for emptying water from filter works great once you've gotten the level down. Another thing that worked great for me was to remove the bottom panel and use a bucket that fit under the door. Open door when water level is high and it dumps in bucket (square works better than round bucket) with almost no mess at all. Empties washer much faster than doing it all in paint tray and cleaner than a pile of towels under door...
May be new pump before day is out at about $60. MUCH cheaper than service technician doing work that is relatively simple. Thanks all...
  #7 (permalink)
Old 03-07-2010, 09:31 AM
thefixitgirl thefixitgirl is offline
Junior Member
thefixitgirl is on a distinguished road
Smile Whirlpool Duet Sport F-33 error code solution
Thank you, thank you, thank you . I followed the steps that were explained here when I got the F-33 code: took off the bottom front panel, found the manual (which didn't help), turned the huge white circle screwlike thing counterclockwise completely around until it popped out, about a cup of water spilled out , mopped it up, took out all the gunk that was there, cleaned everything, put it all back together and now my washer works as good as new. The hardest part was getting the three screws off that holds on the front panel because I don't have a pedestal under the washer and it was hard to get to. I can't believe I would have paid a repairman hundreds of dollars to do what I just did in 10 min. Now I can buy the pedestal with the money I saved! What did people do before the internet????
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirpool Duet Sport doesn't go into high spin Rob2004 Washer Repair 12 12-02-2009 09:46 AM
Duet Sport - not draining (F-21) - grinding noise from pump! Kazura Washer Repair 5 09-05-2009 02:52 PM
whirlpool duet sport washer sheryl luker Washer Repair 1 09-03-2009 08:10 PM
I replaced my pump assembly on my Whirpool Duet!!! frostywashdry Washer Repair 1 04-18-2009 05:27 PM
Duet Sport F01 error Code vposton Washer Repair 2 09-15-2007 07:20 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
