Discuss
washer does not advance in cylce durring rinse cycle
 in
Washer Repair
Hello, I have a Maytag Washer Dryer stacked unit, SE1000. The washer gets stuck on the rinse cycle at "
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer does not advance in cylce durring rinse cycle
  #1 (permalink)
Old 07-10-2008, 06:11 PM
jasollitto jasollitto is offline
Junior Member
jasollitto is on a distinguished road
Default washer does not advance in cylce durring rinse cycle
Model Number: se1000   Brand: Maytag   Age: More than 10 years
Hello,
I have a Maytag Washer Dryer stacked unit, SE1000. The washer gets stuck on the rinse cycle at "2", and does not advance. I can manually select a lesser time when it's stuck and get it to advance to the spin cycle. I thought replacing the circuit board with the timer built in (I'm pretty sure it is built in as I can find no other timer in the unit), but this did not fix the washer. Is there something else I should be fixing?
Thank you,
Jasollitto
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-11-2008, 02:46 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Jasollitto,
This is kind of problem I never seen before with this model (especially if you already replaced the control board). Maybe somebody else on the forum can help you better.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 07-12-2008, 01:33 PM
Junior Member
Thumbs up I figured it out
it was the mixing valve solenoid, the cold water part of the valve would not open, so the tub could not fill during the rinse cycle, and that prevented it from advancing.
  #4 (permalink)
Old 07-14-2008, 07:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wahser Overfills on Rinse Cylce ThomasR Washer Repair 0 06-23-2008 10:31 AM
Maytag won't advance past rinse cycle con10der Washer Repair 3 04-12-2008 10:36 AM
washer cycle won't advance tlaw63 Washer Repair 1 03-11-2008 04:11 PM
Washer won't drain/spin in rinse cylce jimII Washer Repair 2 01-15-2008 12:30 AM
Maytag Atlantis won't go automatically advance to rinse cycle rmjz12 Washer Repair 1 11-15-2007 09:56 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
