I am trying to replace the tub hosing in this washer, I am trying to turn counterclock wise to remove it and it won't budge, have be applying pen oil to loosen it up , but no avail. Am I turning the correct direction to remove hub.:confused: The item I am referring to is under the transmission section on the parts list for this washer, item #7. My greatful thanks for any help in this matter.
You have to have some special tools for this job. Hopefully the Service bulletin will help you. Gene.
Originally Posted by: Gene You have to have some special tools for this job. Hopefully the Service bulletin will help you. Gene. Thank you for the info. Is the tub hub usually very hard to turn? It acts like it is siezed up.
