Occasionally, my washer does not go into a spin and drain. It happens in both the color settings and the whites. It also happens between the wash and rinse as well as the final spin.. The selection knob moves forward as if everything ran correctly. When I reset the selection button to the appropriate spin area on the dial, it will run correctly. This problem only occurs OCCASIONALLY, maybe once out of every dozen washings...
