Discuss
front loader bearing numbers?
 in
Washer Repair
My front-loader makes a slight roaring sound during high-speed spins. There is no play in the inner drum. I suspect
Appliance Repair Forum > Appliance Repair Help > Washer Repair » front loader bearing numbers?
  #1 (permalink)
Old 07-10-2008, 07:53 AM
Junior Member
JonF is on a distinguished road
Default front loader bearing numbers?
Model Number: FWTR445RFS2   Brand: Frigidaire   Age: 5 - 10 years
My front-loader makes a slight roaring sound during high-speed spins. There is no play in the inner drum. I suspect bad bearings (and hope the spider is OK).
My thought is to install higher quality bearings/seals instead of a rear outer tub half with OEM bearings/seals. But, the MRS. doesn't want Mt. Washmore to pose an avalanche threat while I have the unit torn down.
Can anyone tell me the dimensions or numbers on the bearings and seals in this model? Or, if in your experience, my plan is not a good idea, perhaps you could suggest an alternative.
Thank you!
Jon
Ads By Google
Related Models
Frigidaire FWTR445RFS2 Frg(v0) / Front Load Washer
Frigidaire FWTR549GG Frg(v0) / Free Standing Washer
Frigidaire FWTR549GGS0 Frg/washer
Frigidaire FWTR549GS0
Frigidaire FWTR645RHS0 Frtld Wshr - Frigidaire
Frigidaire FWTR645RHS1 Frg(v0) / Front Load Washer
Frigidaire FWTR647GHS0 Frg(v0) / Washer
Frigidaire FWTR647GHS1 Frtld Wshr - Frigidaire
Frigidaire FWTR865RHQ0 Frg(v1) / Front Load Washer
Frigidaire FWTR865RHS0 Frg(v2) / Front Load Washer
Frigidaire FWTR867GHQ0 Frg(v1) / Front Load Washer
Frigidaire FWTR867GHS0 Frg(v2) / Front Load Washer
Frigidaire FWX133RBS0 Frg(v2) / 27 " Washer
Frigidaire FWX133RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX133RBS2 Frg(v1) / Washer
Frigidaire FWX133RBS3 Frg(v1) / Washer
Frigidaire FWX221AS0 Washer - Frigidaire
Frigidaire FWX221AS1 Washer - Frigidaire
Frigidaire FWX221AS2 Frigidaire/washer
Frigidaire FWX223LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX223LBS1 Frg(v0) / 27 " Washer
Frigidaire FWX223LBS2 Frg(v2) / Washer
Frigidaire FWX223LBS3 Frg(v2) / Washer
Frigidaire FWX223LBS4 Frg(v0) / Washer
Frigidaire FWX223LBS5 Frg(v0) / Washer
Frigidaire FWX223LBS6 Frg/washer
Frigidaire FWX223LBS7 Frg(v0) / Free Standing Washer
Frigidaire FWX223LBS8 Frg/washer
Frigidaire FWX225RHS0 Frg(v0) / Washer
Frigidaire FWX225RHS1 Frg/washer
Frigidaire FWX233MRES0 Frg(v0) / Refrigerator
Frigidaire FWX233NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX233NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX233NBS2 Frg(v1) / Washer
Frigidaire FWX233NBS3 Frg(v0) / Washer
Frigidaire FWX233RES0 Frg(v0) / Washer
Frigidaire FWX233RES1 Frg(v0) / Washer
Frigidaire FWX233RES2 Frg(v0) / Washer
Frigidaire FWX233RES3 Frg(v0) / Washer
Frigidaire FWX233RES4 Frg(v0) / Washer
Frigidaire FWX233RES5 Frg(v0) / Washer
Frigidaire FWX233RES6 Frg/washer
Frigidaire FWX233RES7 Washer - Frigidaire
Frigidaire FWX233RET0 Frg(v0) / Free Standing Washer
Frigidaire FWX233RET1 Frg/washer
Frigidaire FWX414RGS0 Frg(v0) / Free Standing Washer
Frigidaire FWX414RGS1 Washer - Frigidaire
Frigidaire FWX433RBS0 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS2 Frg(v3) / Washer
Frigidaire FWX433RBS3 Frg(v1) / Washer
Frigidaire FWX433RBS4 Frg(v1) / Washer
Frigidaire FWX433RBS5 Frg(v1) / Washer
Frigidaire FWX433RBT0 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT1 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT2 Frg(v4) / Washer
Frigidaire FWX433RBT4 Frg(v2) / Washer
Frigidaire FWX433RBT5 Frg(v2) / Washer
Frigidaire FWX435RHS0 Frg(v0) / Washer
Frigidaire FWX435RHS1 Washer - Frigidaire
Frigidaire FWX435RHT0 Frg(v0) / Washer
Frigidaire FWX435RHT1 Washer - Frigidaire
Frigidaire FWX445LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS1 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS2 Frg(v1) / Washer
Frigidaire FWX445LBS3 Frg(v2) / Washer
Frigidaire FWX445LBS4 Frg(v0) / Washer
Frigidaire FWX445NBS0 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS2 Frg(v3) / Washer
Frigidaire FWX445NBS3 Frg(v2) / Washer
Frigidaire FWX445NBS4 Frg(v0) / Washer
Frigidaire FWX445RFS0 Frg(v1) / Washer
Frigidaire FWX445RFS1 Frg(v1) / Washer
Frigidaire FWX445RFS2 Frg(v1) / Washer
Frigidaire FWX445RFS3 Frg(v1) / Washer
Frigidaire FWX445RFS4 Frg(v1) / Free Standing Washer
Frigidaire FWX445RFS5 Washer - Frigidaire
Frigidaire FWX445RFT0 Frg(v2) / Washer
Frigidaire FWX445RFT1 Frg(v2) / Washer
Frigidaire FWX445RFT2 Frg(v2) / Washer
Frigidaire FWX445RFT3 Frg(v2) / Washer
Frigidaire FWX445RFT4 Frg(v2) / Free Standing Washer
Frigidaire FWX645DBD0 Frg(v2) / 27 " Washer
Frigidaire FWX645DBD1 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW0 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW1 Frg(v2) / 27 " Washer
Frigidaire FWX645GES0 Frg(v0) / Washer
Frigidaire FWX645GES1 Frg(v0) / Washer
Frigidaire FWX645LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645LBS1 Frg(v0) / 27 " Washer
Frigidaire FWX645LBS2 Frg(v4) / Washer
Frigidaire FWX645LBS3 Frg(v3) / Washer
Frigidaire FWX645LBS4 Frg(v1) / Washer
Frigidaire FWX645LBT2 Frg(v5) / Washer
Frigidaire FWX645LBT4 Frg(v2) / Washer
Frigidaire FWX645NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS1 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS2 Frg(v2) / Washer
Frigidaire FWX645NBS3 Frg(v0) / Washer
Frigidaire FWX645NBT0 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT1 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT2 Frg(v3) / Washer
Frigidaire FWX645RFS0 Frg(v0) / Washer
Frigidaire FWX645RFS1 Frg(v0) / Washer
Frigidaire FWX6968HW0 Frg(v0) / Washer
Frigidaire FWX6970EW0 Frg(v0) / Washer
Frigidaire FWX6970EW1 Frg(v0) / Washer
Frigidaire FWX6970EW2 Frg(v0) / Washer
Frigidaire FWX6970EW3 Frg(v0) / Washer
Frigidaire FWX6970EW4 Frg/washer
Frigidaire FWX6970EW5 Frg(v0) / Washer
Frigidaire FWX6971EW0 Frg(v0) / Washer
Frigidaire FWX6971EW1 Frg(v0) / Washer
Frigidaire FWX6971EW2 Frg(v0) / Washer
Frigidaire FWX6975EW0 Frg(v0) / Washer
Frigidaire FWX6975EW1 Frg(v0) / Washer
Frigidaire FWX6975EW2 Frg(v0) / Washer
Frigidaire FWX833AS0 Washer - Frigidaire
Frigidaire FWX833AS1 Washer - Frigidaire
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune front loader bad bearing test richappy Washer Repair 5 01-10-2011 01:24 AM
kenmore front loader fell onto front while moving. ohhhden Washer Repair 1 01-26-2010 07:22 PM
Frididaire front loader back bearing Ripley Washer Repair 5 07-09-2009 02:00 PM
sears front loader sounds like rubbing or bearing going out daryljosie Washer Repair 16 04-28-2009 04:28 PM
How do I troubleshoot front door panel light and numbers? Partial #'s and won't start BuddyL Dishwasher Repair 4 12-07-2008 04:16 PM
