recordguy
#1 Posted : Saturday, May 22, 2010 6:56:46 PM(UTC)
recordguy
I cannot close the door on the washer. It seems the lock is engaged constantly. When I try to move timer to the end of a cycle, the latch remains closed and I can't push the door to latch it. Is this a door lock or a timer problem? I even tried unplugging power--didn't help.
Lilbird61
#2 Posted : Thursday, June 17, 2010 12:52:31 PM(UTC)
Lilbird61
Hey I justed wanted to know if you figures out the problem with your washer? I have a GE and it is doing the same hing. Any suggestions?
#3 Posted : Saturday, June 19, 2010 1:22:42 AM(UTC)
If the door catch lines up with the door switch holes, but won't shut, you have a bad door switch. You will need to remove the front bellows with a razor knife to get at the switch after you get the new one, then just use super glue to re-attach the bellows.
