Using this web site, I changed out the old timer (10 years old) with one that is supposed to be compatable. The numbers on the timers differ, however, and after replacing the timer there is no power. There is power to the outlet. The door and the dispensing door are closed and the water is turned back on and connected. Are these 2 timers really compatible? (See numbers below) If they are compatible, any thoughts on what I could do next?
original timer #131725700-C type: 514 094 A 508 replacement #131800500 type: 514 154 00A 437
