washer will spin out but it wont agitate. also i could smell the belt burning. do think the belt is worn out.
fixed the problem of not agitating. the motor roller bearings just needed to be oiled. it would move fine with my hand but would not slide back by itself. would recommend anyone with agitating problems check to see if motor will slide back and forth. that is if you have 2 belt driven washer not direct drive
