My Frigidaire FTF2140FS1 washer will not final spin. Doing the Diagnoistic Test the code came up E43 for Control Board Problem. Other reviews, folks have the same error code and replaced board with no results however replacing the door switch/latch assembly worked. On this model, how do you replace the Door Switch Assembly (with pictures) and to make sure how do you test the old Door Switch Assembly with ohms reader (with pictures). Thanks Jerome
Hi Jerome This service manual will show you how to test it and replace it, but you may also need the speed control board. Check it out also using the instructions in the manual. Also look to check the wiring between the door lock assembly and the control board. http://frigidaireservicetips.co...rizontalAxisWasherSM.pdf
Originally Posted by: sidfink43 Hi Jerome This service manual will show you how to test it and replace it, but you may also need the speed control board. Check it out also using the instructions in the manual. Also look to check the wiring between the door lock assembly and the control board. http://frigidaireservicetips.co...rizontalAxisWasherSM.pdf Thanks Sir, I will work on this over the weekend and let you know the results. Again, thank you for your quick responses to us folks seeking your assistance. Jerome :)
Jerome :)[/qu
I installed the door switch/latch assembly and now the washing machine is working. Thanks to the manual that you provided I installed it without a problem and it took less than 30 minutes. Again, Thank you.
Jerome
Great! Glad that worked out for you and thanks for the update
