| » Timer Issue? |
Model Number: WJSR2080T5WW Brand: GE Age: More than 10 years
GE - WJSR2080T5WW
The Machine never finishs the cycle. Always stops at "soak". I have to manually advance the timer pass the "soak". Do you think this is timer issue? Sincerely, BW Ads By Google Related Models |
You will need a voltmeter to confirm a bad timer. Does it fail in other cycles also, or just one? During this cycle, the timer sends voltage to the water solenoids to let water in, then the water level switch sends voltage to the motor to start agitating once it fills up. You may have other problems, these timers are usually pretty reliable.
__________________
| Display Modes | |
| Frigidaire Timer Issue | mzakal | Dryer Repair | 1 | 04-22-2010 09:32 AM |
| Timer Issue | dps3e@aol.com | Dryer Repair | 1 | 02-27-2010 07:11 AM |
| Possible timer issue? | plow509 | Washer Repair | 1 | 01-20-2010 11:09 AM |
| timer issue?? | ldutton | Washer Repair | 5 | 10-26-2009 10:38 AM |
| Timer issue? | Chriskall | Dishwasher Repair | 3 | 09-23-2009 12:36 PM |
