My '05 Model Will Begin To Fill, To Start A Wash Cycle, Then Stop With Fh Error Code (water Inlet Flow). With The Lid Off, I Would Touch Every Electrical Plug I Could See, To Snug The Connections, And It Would Run, Trouble-free...sometimes For Months. Then It Would Happen Again, Then Again And Again With Greater Frequency. Eventually, The Touching Of The Electrical Connections Failed To Correct The Problem. I Have Checked The Inlet Valve Screens; I Have Pulled The Water Inlet Monitor (which Is Clean And Turning Smoothly; I Have Connected A Longer Hose From The Inlet Monitor To A Bucket, Started A Cycle, Water Runs Free And Strong, And All Is Clear.
I Can't Get The Washer To Run Through A Complete Cycle, Now, Regardless Of The Times I Restart It.
Any Suggestions????
