Discuss
My washing machine fills with water, but that's it
 in
Washer Repair
My washing machine fills with water, but that's it; it does nothing else. The timer does not advance after filled
Appliance Repair Forum > Appliance Repair Help > Washer Repair » My washing machine fills with water, but that's it
  #1 (permalink)
Old 07-05-2008, 01:06 PM
Junior Member
pejza is on a distinguished road
Default My washing machine fills with water, but that's it
Model Number: GUSR2100W1ww   Brand: GE   Age: 1 - 5 years
My washing machine fills with water, but that's it; it does nothing else. The timer does not advance after filled with water or make any noises if i advance the timer to spin, its drain out water but no spinning.
Thanks for your help
Related Models
Maytag GV1110PRW RANGE- F/S STD GAS
Admiral GV1226NXEW FREEZER- VERTICAL
Admiral GV1726NXEW FREEZER- VERTICAL
Hoover GV3177WUA RANGE- F/S STD GAS
Hoover GV3177WUW RANGE- F/S STD GAS
Hoover GV3177WUW5 RANGE- F/S STD GAS
Maytag GV3277XUA RANGE- F/S STD GAS
Maytag GV3277XUW RANGE- F/S STD GAS
Hoover GV3531WUA RANGE- F/S STD ELE
Hoover GV3531WUW RANGE- F/S STD ELE
General Electric GVSR1060H7WW WASHER
General Electric GVSR1060H9WW WASHER
General Electric GVSR1080H8WW WASHER
Whirlpool GVW9959KL0 WASHER
Whirlpool GVW9959KL1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KL2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KL3 AUTOMATIC WASHER
Whirlpool GVW9959KQ0 WASHER
Whirlpool GVW9959KQ1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KQ2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KQ3 AUTOMATIC WASHER
Whirlpool GVW9959KT0 WASHER
Whirlpool GVW9959KT1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KT2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KT3 AUTOMATIC WASHER
Maytag GW18F1A WASHER-TOP LOADING
Maytag GW18F1H WASHER-TOP LOADING
Maytag GW18F1W WASHER-TOP LOADING
Maytag GW18F2A WASHER-TOP LOADING
Maytag GW18F2H WASHER-TOP LOADING
Maytag GW18F2W WASHER-TOP LOADING
Maytag GW18G1A WASHER-TOP LOADING
Maytag GW18G1HW WASHER-TOP LOADING
Maytag GW18G1WW WASHER-TOP LOADING
Maytag GW20F6A WASHER-TOP LOADING
Maytag GW20F6H WASHER-TOP LOADING
Maytag GW20F6W WASHER-TOP LOADING
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0 GAS RANGE
Whirlpool GW395LEGB1 GAS RANGE
Whirlpool GW395LEGB2 GAS RANGE
Whirlpool GW395LEGB3 GAS RANGE
Whirlpool GW395LEGB4 GAS RANGE
Whirlpool GW395LEGB5 GAS RANGE
Whirlpool GW395LEGB6 GAS RANGE
Whirlpool GW395LEGQ0 GAS RANGE
Whirlpool GW395LEGQ1 GAS RANGE
Whirlpool GW395LEGQ2 GAS RANGE
Whirlpool GW395LEGQ3 GAS RANGE
Whirlpool GW395LEGQ4 GAS RANGE
Whirlpool GW395LEGQ5 GAS RANGE
Whirlpool GW395LEGQ6 GAS RANGE
Whirlpool GW395LEGT2 GAS RANGE
Whirlpool GW395LEGT3 GAS RANGE
Whirlpool GW395LEGT4 GAS RANGE
Whirlpool GW395LEGT5 GAS RANGE
Whirlpool GW395LEGT6 GAS RANGE
Whirlpool GW395LEGZ0 GAS RANGE
Whirlpool GW395LEGZ1 GAS RANGE
Whirlpool GW395LEGZ2 GAS RANGE
Whirlpool GW395LEGZ3 GAS RANGE
Whirlpool GW395LEPB00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW397LXUB0 30" Gas Slide-In
Whirlpool GW397LXUB05 30" GAS SLIDE-IN
Whirlpool GW397LXUB06 30" GAS SLIDE-IN RANGE
Whirlpool GW397LXUB1 30" GAS SLIDE-IN
Whirlpool GW397LXUB5 30" GAS SLIDE-IN
Whirlpool GW397LXUQ0 30" Gas Slide-In
Whirlpool GW397LXUQ06 30" GAS SLIDE-IN
Whirlpool GW397LXUQ1 30" GAS SLIDE-IN
Whirlpool GW397LXUQ6 30" GAS SLIDE-IN
Whirlpool GW397LXUS0 30" Gas Slide-In
Whirlpool GW397LXUS05 30" GAS SLIDE-IN
Whirlpool GW397LXUS06 30" GAS SLIDE-IN RANGE
Whirlpool GW397LXUS1 30" GAS SLIDE-IN
Whirlpool GW397LXUS5 30" GAS SLIDE-IN
Whirlpool GW397LXUT0 30" Gas Slide-In
Whirlpool GW397LXUT05 30" GAS SLIDE-IN
Whirlpool GW397LXUT06 30" GAS SLIDE-IN
Whirlpool GW397LXUT1 30" GAS SLIDE-IN
Whirlpool GW397LXUT5 30" GAS SLIDE-IN
Whirlpool GW399LXUB0 30" Gas Slide-In
Whirlpool GW399LXUB05 30" GAS SLIDE-IN
Whirlpool GW399LXUB06 30" GAS SLIDE-IN RANGE
Whirlpool GW399LXUB1 30" Gas Slide-In
Whirlpool GW399LXUB5 30" Gas Slide-In
Whirlpool GW399LXUQ0 30" Gas Slide-In
Whirlpool GW399LXUQ06 30" GAS SLIDE-IN
Whirlpool GW399LXUQ1 30" Gas Slide-In
Whirlpool GW399LXUQ6 30" Gas Slide-In
Whirlpool GW399LXUS0 30" Gas Slide-In
Whirlpool GW399LXUS04 30" GAS SLIDE-IN
Whirlpool GW399LXUS05 30" GAS SLIDE-IN
Whirlpool GW399LXUS06 30" GAS SLIDE-IN RANGE
  #2 (permalink)
Old 07-05-2008, 02:17 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
You'll need to check your door switch, sound like it may be bad.
__________________
  #3 (permalink)
Old 07-12-2008, 01:47 PM
Junior Member
Default
yes , it is door switch one on the wire was disconnected.
How can I remove door switch?(take it out)
Thank you!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washing machine won't spin the water out it jgosch Washer Repair 0 05-09-2009 12:05 PM
Tub fills and then drain, washing machine papapierre Washer Repair 2 08-09-2008 09:01 AM
Tappan Washing machine fills but won't agitate sikupandfed Washer Repair 0 07-23-2008 01:06 PM
washing machine fills and drains same time imagiggles Washer Repair 2 07-17-2008 11:36 PM
My washing machine fills water, but that's it Cougy Washer Repair 4 07-01-2008 09:28 PM
