Discuss
Uni-Direction Agitate
 in
Washer Repair
Our washer fills, spins, and rinses properly. However during the agitation cycle, the agitator, moves and stops in rapid succession.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Uni-Direction Agitate
  #1 (permalink)
Old 05-15-2010, 12:40 PM
Junior Member
llmmnnoopp is on a distinguished road
Default Uni-Direction Agitate
Model Number: KAWS750GQ1   Brand: Kitchen Aid   Age: More than 10 years
Our washer fills, spins, and rinses properly. However during the agitation cycle, the agitator, moves and stops in rapid succession. When the agitator stops there is a ratcheting sound for maybe five clicks, instead of a reverse motion.
The final result is the cloths and water moving in only a counter-clockwise direction during the agitation cycle and getting tightly wrapped around the agitator.
What do I replace to fix?
Thanks!
Ads By Google
Related Models
Whirlpool KAWS750GQ1
Whirlpool KAWS750GT1
Whirlpool KAWS750GZ0
Whirlpool KAWS750GZ1
Whirlpool KAWS750JQ0
Whirlpool KAWS750JQ1
Whirlpool KAWS750JQ2
Whirlpool KAWS750JQ3
Whirlpool KAWS750JQ4
Whirlpool KAWS750JT0
Whirlpool KAWS750JT1
Whirlpool KAWS750JT2
Whirlpool KAWS750JT3
Whirlpool KAWS750JT4
Whirlpool KAWS750LQ0 Automatic Washer
Whirlpool KAWS750LQ1 Automatic Washer
Whirlpool KAWS750LQ2 Automatic Washer
Whirlpool KAWS750LQ3 Automatic Washer
Whirlpool KAWS750LQ4 Automatic Washer
Whirlpool KAWS750LT0 Automatic Washer
Whirlpool KAWS750LT1 Automatic Washer
Whirlpool KAWS750LT2 Automatic Washer
Whirlpool KAWS750LT3 Automatic Washer
Whirlpool KAWS750LT4 Automatic Washer
Whirlpool KAWS777EQ0
Whirlpool KAWS777EZ0
Whirlpool KAWS800GQ0
Whirlpool KAWS800GQ1
Whirlpool KAWS800GZ0
Whirlpool KAWS800GZ1
Whirlpool KAWS850GQ0
Whirlpool KAWS850GQ1
Whirlpool KAWS850GT0
Whirlpool KAWS850GT1
Whirlpool KAWS850GZ0
Whirlpool KAWS850GZ1
Whirlpool KAWS850JQ0
Whirlpool KAWS850JQ1
Whirlpool KAWS850JQ2
Whirlpool KAWS850JQ3
Whirlpool KAWS850JQ4
Whirlpool KAWS850JT0
Whirlpool KAWS850JT1
Whirlpool KAWS850JT2
Whirlpool KAWS850JT3
Whirlpool KAWS850JT4
Whirlpool KAWS850LE0
Whirlpool KAWS850LE1 Automatic Washer
Whirlpool KAWS850LE2 Automatic Washer
Whirlpool KAWS850LQ0
Whirlpool KAWS850LQ1 Automatic Washer
Whirlpool KAWS850LQ2 Automatic Washer
Whirlpool KAWS850LT0
Whirlpool KAWS850LT1 Automatic Washer
Whirlpool KAWS850LT2 Automatic Washer
Whirlpool KAWS855JE0
Whirlpool KAWS855JE1
Whirlpool KAWS855JE2
Whirlpool KAWS855JE3
Whirlpool KAWS855JE4
Whirlpool KAWS977EQ0
Whirlpool KAWS977EZ0
Bosch KB030-062
Bosch KB032-062
Bosch KB035-062
Bosch KB036-062
Bosch KB090-054
Bosch KB091-054
Bosch KB100-046
Frigidaire KB122G0 Wwh(v1) / Built - in Oven
Frigidaire KB122G1 Wwh(v2) / Built - in Oven
Frigidaire KB122G2 Wwh(v3) / Built - in Oven
Frigidaire KB122G3 Wwh(v4) / Built - in Oven
Frigidaire KB122G4 Wwh(v5) / Built - in Oven
Frigidaire KB122LM0 Wwh(v1) / Wall Oven
Frigidaire KB122LM1 Wwh(v2) / Wall Oven
Frigidaire KB122LM2 Wwh(v1) / Wall Oven
Frigidaire KB122LMO Wwh(v1) / Wall Oven
Frigidaire KB152LM0 Wwh(v1) / Electric Range
Frigidaire KB152LM1 Wwh(v1) / Electric Range
Frigidaire KB152LM2 Wwh(v1) / Electric Range
Whirlpool KB26G1X-3 6 Qt. Stand Mixer
Whirlpool KB26G1XAC3 6 Qt. Stand Mixer
Whirlpool KB26G1XAC5 6 Qt. Stand Mixer
Whirlpool KB26G1XBU3 6 Qt. Stand Mixer
Whirlpool KB26G1XBU5 6 Qt. Stand Mixer
Whirlpool KB26G1XER3 6 Qt. Stand Mixer
Whirlpool KB26G1XER5 6 Qt. Stand Mixer
Whirlpool KB26G1XGN3 6 Qt. Stand Mixer
Whirlpool KB26G1XGR3 6 Qt. Stand Mixer
Whirlpool KB26G1XGR5 6 Qt. Stand Mixer
Whirlpool KB26G1XMC3 6 Qt. Stand Mixer
Whirlpool KB26G1XMC5 6 Qt. Stand Mixer
Whirlpool KB26G1XMY3 6 Qt. Stand Mixer
Whirlpool KB26G1XMY5 6 Qt. Stand Mixer
Whirlpool KB26G1XOB3 6 Qt. Stand Mixer
Whirlpool KB26G1XOB5 6 Qt. Stand Mixer
Whirlpool KB26G1XPT3 6 Qt. Stand Mixer
Whirlpool KB26G1XPT5 6 Qt. Stand Mixer
Whirlpool KB26G1XTG3 6 Qt. Stand Mixer
Whirlpool KB26G1XTG5 6 Qt. Stand Mixer
Whirlpool KB26G1XWW3 6 Qt. Stand Mixer
Whirlpool KB26G1XWW5 6 Qt. Stand Mixer
Whirlpool KB3SS
Frigidaire KB443GDM0 Wwh(v1) / Electric Continuous Clean Oven
Frigidaire KB443GDM1 Wwh(v2) / Electric Continuous Clean Oven
Frigidaire KB443GDM2 Wwh(v1) / Electric Range
Frigidaire KB443LM1 Wwh(v1) / Electric Range
Frigidaire KB563LM0 Wwh(v1) / Wall Oven
Frigidaire KB663GDM0 Wwh(v1) / Electric Self - Clean Oven
Frigidaire KB663GDM1 Wwh(v2) / Electric Self - Clean Oven
Frigidaire KB663GDM2 Wwh(v1) / Wall Oven
Frigidaire KB663LM0 Wwh(v1) / Electric Range
Frigidaire KB663LM1 Wwh(v1) / Electric Range
Frigidaire KB663LM2 Wwh(v1) / Electric Range
Frigidaire KB663LMO Wwh(v0) / Electric Range
Frigidaire KB883GDM1 Wwh(v1) / Electric Double Oven W/self Clean Upper
Frigidaire KB883GDM2 Wwh(v1) / Electric Range
Frigidaire KB883GDM3 Wwh(v2) / Electric Range
Frigidaire KB883GDMO Wwh(v2) / Electric Double Oven W/self Clean Upper
  #2 (permalink)
Old 05-16-2010, 01:54 PM
Junior Member
Default
BTW: I already replaced the dawgs.
  #3 (permalink)
Old 05-17-2010, 09:33 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Rather rare, but your agitator stripped out. Remove the 7/16 bolt under the cap and pull off to check the splindle . If ok, you just might have a bad transmission.
If ok, your transmission coupler broke while agitating and now it will not spin either.
__________________
  #4 (permalink)
Old 05-17-2010, 09:57 AM
Junior Member
Default
Richappy,
Thanks for your reply! I have torn it all down. The spindle itself and the grooves in the plastic part of the agitator that it mates with are both in good condition.
Saturday I even went so far as to open the gearbox and fish out all the gears looking for a gear missing some teeth or maybe one of the parts somehow obviously broken... no luck. The only thing I couldn't do, because of the complete mess it would have been, was check out that worm gear. However I suspect it is fine because spin continues to work well.
Could worn brakes or clutch be the culprit? They both seem to work well enough when I have the thing torn apart, but perhaps under load they fail...
I'm puzzled. I'd buy a new gearbox in a second if I could somehow be sure that was the problem... just not sure at this point... any other thoughts?
  #5 (permalink)
Old 05-18-2010, 04:17 AM
Senior Expert
APP Volunteer
Default
I would pull the tranny, stick the agitator on, and turn the tranny coupler counterclockwise, agitator should move back and forth. If not=new tranny time.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jennair direction switch doug1952 Trash Compactor Repair 0 04-05-2010 01:24 PM
Agitates in only one direction. bteddy Washer Repair 0 08-31-2009 04:06 PM
Direction for Sidewinder Motor SPUD Dishwasher Repair 2 10-24-2007 03:07 PM
