On regular cycle washer fills then starts wash. A few minutes into wash the timer stops and you have to turn knob manually to drain. Could be during switching from high speed to low speed, is this a timer problem? (Could be its almost 20 years old)
Thanks, Avnger
Sounds like the timer, this part here. Part number: AP3099903
If you order from this site and it does not solve the problem you may be able to return it, see the returns policy.
