Discuss
Burning Washer Belts
 in
Washer Repair
Washer started to smell like burning rubber. I pulled the cover to find the belt was burnt in one spot.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Burning Washer Belts
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-04-2008, 11:03 PM
tnichols tnichols is offline
Junior Member
tnichols is on a distinguished road
Default Burning Washer Belts
Model Number: MWX111REW0   Brand: White-Westinghouse   Age: 1 - 5 years
I bought a new belt and after about 20 wash loads, the belt was burning again.
I just bought a second new belt and installed it. Now I can smell it burning again. I felt the motor pully and it was very hot. Actually burnt my fingers. I wonder if the pully should be that hot?
Washer works through all cycles. But continues to burn belts. I don't see any broken parts and everything seems to move freely. But you can smell the rubber belt bruning. Every now and then I can hear someting rattling in there somewhere, but I can't tell where it is coming from.
Not sure what to check next. Maybe its time for a new washer?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-06-2008, 07:31 AM
Junior Member
Default
I bought another spare belt and I am using the washer. It is working, but the belt and pully still gets very hot. I guess if it happens again, I should just buy a new washer. Unless anyone else has any other ideas? I am stumped on this one.
  #3 (permalink)
Old 08-27-2008, 07:44 AM
bmar bmar is offline
Junior Member
bmar is on a distinguished road
Default
What did you end up doing? I am having the same problem. This is the first time it has happened to me. One belt did break but now it was smoking and rubber smell. I am not for sure what to do. I started to do a test run but it still is giving off the burnt smell. I wish some one knew what to do.
  #4 (permalink)
Old 08-27-2008, 09:24 AM
Junior Member
Default
Quote:
First thing I did was to buy two belts, so I had a quick spare. Then I sanded down the pullies. They were rough. I smoothed the part of the pully where the belt runs. Its been a few weeks (in a rental house) and so far it is holding and not smoking.
Good luck with yours, Tom...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
diagram for dryer belts zahi Dryer Repair 1 06-11-2008 02:57 PM
washer has burning smell!! cdestuck Washer Repair 5 05-01-2008 11:47 AM
Kenmore washer burning up GeorgeG Washer Repair 0 01-25-2008 10:09 PM
Won't drain all water/not belts chareng Washer Repair 0 01-25-2008 05:40 PM
Dryer belts charliegirl Dryer Repair 1 11-11-2007 03:40 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
