I have a Maytag Neptune front load washer and I have an error code 3E, looking at the trouble shooting guide it say that it could be the motor winding or the control board. I checked the ohms on the pin connector at the control board and the were 3.0 to 1.8. The book say that it is normal for it to read 11.6. Is this reading ok of is it too low. I also check the motor windings from the wiring harness connector and it read 15.2 on all three wires, it this ok or should it be lower? If this is ok what else should I check before taking the washer to the shop. If it is the motor it is still covered under warranty. Any information would be great. Thanks Scott
