Discuss
Washer Does Not Go Through Cycles
 in
Washer Repair
Our top load washer begins to agitate as soon as we turn it on when it begins to fill. The
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Does Not Go Through Cycles
  #1 (permalink)
Old 07-04-2008, 07:54 AM
jopoc jopoc is offline
Junior Member
jopoc is on a distinguished road
Question Washer Does Not Go Through Cycles
Model Number: LAT9206BAE   Brand: Maytag   Age: 1 - 5 years
Our top load washer begins to agitate as soon as we turn it on when it begins to fill. The timer does its thing, but agitation does not stop unless we open and close the lid when the timer indicator points at the next cycle. Replaced the timer, but that did not help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-04-2008, 10:29 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Make sure you have the right timer for the washer, if so, you probably have a stuck water level switch, just confirm with ohm meter.
__________________
  #3 (permalink)
Old 07-23-2008, 06:34 PM
Junior Member
Default
OK, Ill bite. Where is the switch?
  #4 (permalink)
Old 07-24-2008, 03:16 AM
Senior Expert
APP Volunteer
Default
It's on the left side of the control panel, just replace it if you have no meter.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Not Going Thru Most Cycles ncnicholson Washer Repair 3 11-29-2007 09:17 PM
washer will not change cycles automatically bad bart Washer Repair 0 10-16-2007 01:23 PM
washer stops at different cycles kfoerster Washer Repair 3 09-27-2007 03:37 AM
Countdown Display INOP, Washer cycles normally Julia Dishwasher Repair 0 08-20-2007 10:03 PM
Whirlpool washer will not advance cycles GARY H Washer Repair 0 08-14-2007 07:18 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
