| » Cabrio violently shakes in spin |
Model Number: WTW6200SW1 Brand: Whirlpool Age: 1 - 5 years
Cabrio washer is violently shaking in spin. It was recently moved, so assumed a suspension rod or spring misaligned, but all check out. Did get a few loads done after move without problems anyway. Checked for foreign item impairing movement, nothing. Tore down whole machine, agitator looks good, cams good, tub secured, splines intact on agitator and motor shaft, tub floating up and then returning onto splines at correct times, water drains when it should, from bottom motor cover, stator, sensors taken apart and no visible damage, counterweight did not get knocked off, pulled tub, both balance rings have fluid, but hard to tell if it is equal or correct. At a loss here. I replaced control board recently, could a programming issue do it? Thing sounds like its going to tear itself apart on spin, if it doesn't I may take a sledge hammer officespace style to it though. Thank you for input or advice in advance.
| Display Modes | |
| Kenmore 80 series - shakes bad during spin | OrangeEXS | Washer Repair | 1 | 04-21-2010 07:11 AM |
| washer shakes violently sometimes while spinning | dconradj | Washer Repair | 7 | 03-04-2009 01:42 PM |
| washer shakes during spin cycle | 11newhouse | Washer Repair | 3 | 02-27-2009 06:56 PM |
| shakes bad on spin cycle | allen j | Washer Repair | 1 | 01-28-2009 02:38 PM |
| Front load tub bounces violently in spin cycle | karassdh | Washer Repair | 1 | 01-02-2009 05:48 AM |
