Discuss
water does not fill normally
 in
Washer Repair
The water flow for cold water comes in as just a dribble. Hot water comes in full force. this is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » water does not fill normally
  #1 (permalink)
Old 05-11-2010, 06:35 PM
Junior Member
njbiggs2244 is on a distinguished road
Default water does not fill normally
Model Number: LA6800XTN0   Brand: Whirlpool   Age: More than 10 years
The water flow for cold water comes in as just a dribble. Hot water comes in full force. this is an intermittant problem that started a couple of weeks ago and seems to be getting more frequent.
Ads By Google
Related Models
Whirlpool LA6800XTN0
Whirlpool LA6800XTN1
Whirlpool LA6800XTW0
Whirlpool LA6800XTW1
Whirlpool LA6805XKW2
Whirlpool LA6888XTF0
Whirlpool LA6888XTG0
Whirlpool LA6888XTG1
Whirlpool LA6888XTM0
Whirlpool LA6888XTN0
Whirlpool LA6888XTN1
Whirlpool LA6888XTW0
Whirlpool LA6888XTW1
Whirlpool LA6900XKW1
Whirlpool LA6900XKW2
Whirlpool LA6905XKW1
Maytag LA6910 Washer - Top Loading
Whirlpool LA7000XKW0
Whirlpool LA7000XKW1
Whirlpool LA7000XKW2
Whirlpool LA7000XMW0
Whirlpool LA7000XPW0
Whirlpool LA7000XPW1
Whirlpool LA7000XSW0
Whirlpool LA7000XSW1
Whirlpool LA7000XTF0
Whirlpool LA7000XTF1
Whirlpool LA7000XTG0
Whirlpool LA7000XTG1
Whirlpool LA7000XTM0
Whirlpool LA7000XTM1
Whirlpool LA7000XTN0
Whirlpool LA7000XTN1
Whirlpool LA7000XTW0
Whirlpool LA7000XTW1
Whirlpool LA7001XSW0
Whirlpool LA7001XTF1
Whirlpool LA7001XTG1
Whirlpool LA7001XTM1
Whirlpool LA7001XTN1
Whirlpool LA7001XTW0
Whirlpool LA7001XTW1
Whirlpool LA7005XKW0
Whirlpool LA7005XKW1
Whirlpool LA7005XMW0
Whirlpool LA7005XPW0
Whirlpool LA7005XPW1
Frigidaire LA700AXD1 Wwh(v4) / 27 " Washer
Frigidaire LA700AXD2 Wwh(v4) / 27 " Washer
Frigidaire LA700AXD3 Wwh(v3) / 27 " Washer
Frigidaire LA700AXW1 Wwh(v3) / 27 " Washer
Frigidaire LA700AXW2 Wwh(v3) / 27 " Washer
Frigidaire LA700AXW3 Wwh(v4) / 27 " Washer
Frigidaire LA700MXD1 Wwh(v6) / 27 " Washer
Frigidaire LA700MXW1 Wwh(v5) / 27 " Washer
Maytag LA702 Washer - Top Loading
Whirlpool LA7088XTF0
Whirlpool LA7088XTF1
Whirlpool LA7088XTG0
Whirlpool LA7088XTG1
Whirlpool LA7088XTM0
Whirlpool LA7088XTM1
Whirlpool LA7088XTN0
Whirlpool LA7088XTN1
Whirlpool LA7088XTW0
Whirlpool LA7088XTW1
Maytag LA710 Washer - Top Loading
Maytag LA710S Washer - Top Loading
Maytag LA712 Washer - Top Loading
Maytag LA712T Washer - Top Loading
Maytag LA7300 Washer - Top Loading
Maytag LA7400 Washer - Top Loading
Whirlpool LA7400XMW0
Whirlpool LA7400XMW1
Whirlpool LA7400XMW2
Whirlpool LA7400XMW3
Whirlpool LA7450XMW0
Whirlpool LA7450XMW1
Whirlpool LA7460XMW0
Maytag LA7500 Washer - Top Loading
Maytag LA7500S Washer - Top Loading
Maytag LA7500W Washer - Top Loading
Whirlpool LA7500XKW0
Frigidaire LA750EXD3 Wwh(v6) / Washer
Frigidaire LA750EXF3 Wwh(v7) / Washer
Frigidaire LA750EXH3 Wwh(v8) / Washer
Frigidaire LA750EXV3 Wwh(v9) / Washer
Frigidaire LA750EXW3 Wwh(v10) / Washer
Frigidaire LA750MXD1 Wwh(v2) / 27 " Washer
Frigidaire LA750MXW1 Wwh(v1) / 27 " Washer
Whirlpool LA7680XKW0
Whirlpool LA7680XKW1
Whirlpool LA7680XKW2
Whirlpool LA7680XMW0
Whirlpool LA7680XPW0
Whirlpool LA7680XPW1
Whirlpool LA7680XPW2
Whirlpool LA7680XSW0
Whirlpool LA7680XSW1
Whirlpool LA7680XTF0
Whirlpool LA7680XTF1
Whirlpool LA7680XTG0
Whirlpool LA7680XTG1
Whirlpool LA7680XTM0
Whirlpool LA7680XTM1
Whirlpool LA7680XTN0
Whirlpool LA7680XTN1
Whirlpool LA7680XTW0
Whirlpool LA7680XTW1
Whirlpool LA7681XSW0
Whirlpool LA7681XSW1
Whirlpool LA7685XKW0
Whirlpool LA7685XKW1
Whirlpool LA7685XMW0
Whirlpool LA7685XPW0
Whirlpool LA7685XPW1
Whirlpool LA7685XPW2
Whirlpool LA7700XPW0
Whirlpool LA7700XPW1
Whirlpool LA7700XPW3
  #2 (permalink)
Old 05-14-2010, 01:43 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
A couple of possibilities here, none of them difficult or expensive to fix.
1. Take off the cold water hose and stick it in the machine or sink and turn on the valve, see if water is coming out. If not the problem is in your water line.
2. Check the inlet screen inside the cold water valve, it is easy to get clogged.
3. Take off the cabinet check to make sure 120v is coming to the valve when it is supposed to be on (cold water wash fill or rinse fill).
4. If all checks out, replace the valve assembly, this part here
Part number: AP3094541
This video will show you how to remove the cabinet to get to the valve.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
__________________
  #3 (permalink)
Old 05-14-2010, 03:20 PM
Junior Member
Smile Thank you for the suggestions
We took the cold water hose off of the machine and cleaned out the filter. That seems to have fixed our problem.
  #4 (permalink)
Old 05-14-2010, 05:02 PM
Senior Expert
APP Volunteer
Default
Great, thanks for the update
__________________
  #5 (permalink)
Old 05-15-2010, 04:45 PM
Junior Member
Default continuing saga...
the washer continued with the intermittent water flow problems so we replaced the intake valve and, while we were at it, the water hoses. I think the washer is fixed, but one of the water cut off valves (that are attached to the house) was leaking and we broke it when we tried to replace it. My husband is at the hardware store trying to get the correct part to fix it now so that we don't have to call in the plumber.
  #6 (permalink)
Old 05-15-2010, 05:07 PM
Senior Expert
APP Volunteer
Default
Well this is good in that it broke while you were there, and not while you were out for days or weeks. Check the other one too, its a good idea to replace both since problems with one may mean problems with the other in the future.
Sounds like you have the washer repair under control. Great!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
won't fill with water mario_satx Dishwasher Repair 0 12-29-2009 07:50 AM
hot water will not fill busyjaymom Washer Repair 1 11-30-2009 10:11 AM
water only fill s once nichols Dishwasher Repair 0 07-30-2009 03:30 PM
water only fill s once nichols Dishwasher Repair 0 07-30-2009 03:28 PM
Water won't fill. IHAA Dishwasher Repair 2 06-09-2009 09:07 AM
