Discuss
Agitator will not spin
 in
Washer Repair
The washer will load with water, then nothing happens. I have replaced the timer. The tub spins freely. The ceramic
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Agitator will not spin
  #1 (permalink)
Old 05-11-2010, 10:06 AM
Junior Member
Jayjames is on a distinguished road
Default Agitator will not spin
Model Number: 417.42142100   Brand: Kenmore   Age: 5 - 10 years
The washer will load with water, then nothing happens. I have replaced the timer. The tub spins freely. The ceramic fuse 12A 250V is blown open. I can get a replacement fuse for less than $4 but will it just blow again? Must the entire circuit board (Speed Control Unit) be replaced just because the fuse is blown? I have checked the resistance (ohms) of the motor...spec say it should read 2.6 plus/minus 7% which is 2.78-2.42. All my motor reading were 3.0-3.1 ohms. Does that mean the motor is good.
What further testing can I do, or what should I replace?
Ads By Google
Related Models
Kenmore 417.42142100  WASHER
Kenmore 417.43042200  SEARS/FRONTLOAD WASHER
Kenmore 417.43052200  SEARS/FRONTLOAD WASHER
Kenmore 417.43142200  SEARS/FRONTLOAD WASHER
Kenmore 417.59012890  GAS DRYER
Kenmore 417.69042990  KENMORE DRYER
Kenmore 417.69042991  DRYER
Kenmore 417.69052990  DRYER
Kenmore 417.69052991  ELECTRIC DRYER
Kenmore 417.79042990  DRYER
Kenmore 417.79042991  DRYER
Kenmore 417.79052990  DRYER
Kenmore 417.79052991  DRYER
Kenmore 417.80032990  DRYER
Kenmore 417.80042990  DRYER
Kenmore 417.80042991  DRYER
Kenmore 417.80052990  DRYER
Kenmore 417.80052991  DRYER
Kenmore 417.80142000  DRYER
Kenmore 417.81042000  DRYER
Kenmore 417.81042001  DRYER
Kenmore 417.81052000  ELECTRIC DRYER
Kenmore 417.81052001  DRYER
Kenmore 417.81142000  DRYER
Kenmore 417.81142001  DRYER
Kenmore 417.82042100  DRYER
Kenmore 417.82042101  DRYER
Kenmore 417.82042102  SEARS/DRYER
Kenmore 417.82052100  DRYER
Kenmore 417.82052101  DRYER
Kenmore 417.82052102  DRYER
Kenmore 417.82052103  SEARS/ELECTRIC DRYER
Kenmore 417.82142100  DRYER
Kenmore 417.82142101  DRYER
Kenmore 417.82142102  SEARS/ELECTRIC DRYER
Kenmore 417.83042200  SEARS/DRYER
Kenmore 417.83042201  SEARS/ELECTRIC DRYER
Kenmore 417.83052200  SEARS/DRYER
Kenmore 417.83052201  SEARS/DRYER
Kenmore 417.83142200  SEARS/DRYER
Kenmore 417.83142201  SEARS/ELECTRIC DRYER
Kenmore 417.88988100  ELECTRIC DRYER
Kenmore 417.88988800  ELECTRIC DRYER
Kenmore 417.88989100  GAS DRYER
Kenmore 417.88989800  GAS DRYER
Kenmore 417.89090100  WASHER DRYER COMBINATION
Kenmore 417.89090110  COMBINATION WASHER-DRYER
Kenmore 417.89090200  WASHER DRYER COMBINATION
Kenmore 417.89090210  COMBINATION WASHER-DRYER
Kenmore 417.89090400  WASHER DRYER COMBINATION
Kenmore 417.89090410  COMBINATION WASHER-DRYER
Kenmore 417.89090600  WASHER DRYER COMBINATION
Kenmore 417.89090610  COMBINATION WASHER-DRYER
Kenmore 417.89090800  WASHER DRYER COMBINATION
Kenmore 417.89090810  COMBINATION WASHER-DRYER
Kenmore 417.90032990  DRYER
Kenmore 417.90042990  DRYER
Kenmore 417.90042991  DRYER
Kenmore 417.90052990  DRYER
Kenmore 417.90052991  DRYER
Kenmore 417.90142000  DRYER
Kenmore 417.90802990  LAUNDRY CENTER
Kenmore 417.90802991  LAUNDRY CENTER
Kenmore 417.90802992  LAUNDRY CENTER
Kenmore 417.90807990  LAUNDRY CENTER
Kenmore 417.90812990  LAUNDRY CENTER
Kenmore 417.90812991  LAUNDRY CENTER
Kenmore 417.90812992  LAUNDRY CENTER
Kenmore 417.90814000  LAUNDRY CENTER
Kenmore 417.90814001  LAUNDRY CENTER
Kenmore 417.90814002  LAUNDRY CENTER
Kenmore 417.90817990  LAUNDRY CENTER
Kenmore 417.90862990  LAUNDRY CENTER
Kenmore 417.90862991  LAUNDRY CENTER
Kenmore 417.90862992  LAUNDRY CENTER
Kenmore 417.90872990  LAUNDRY CENTER
Kenmore 417.90872991  LAUNDRY CENTER
Kenmore 417.90872992  LAUNDRY CENTER
Kenmore 417.91042000  DRYER
Kenmore 417.91042001  DRYER
Kenmore 417.91052000  GAS DRYER
Kenmore 417.91052001  DRYER
Kenmore 417.91142000  DRYER
Kenmore 417.91142001  DRYER
Kenmore 417.91702000  LAUNDRY CENTER
Kenmore 417.91702001  LAUNDRY CENTER
Kenmore 417.92042100  DRYER
Kenmore 417.92042101  DRYER
Kenmore 417.92042102  SEARS/GAS DRYER
Kenmore 417.92052101  DRYER
Kenmore 417.92052102  DRYER
Kenmore 417.92052103  SEARS/GAS DRYER
Kenmore 417.92142100  DRYER
Kenmore 417.92142101  DRYER
Kenmore 417.92142102  SEARS/GAS DRYER
Kenmore 417.92702200  LAUNDRY CENTER
Kenmore 417.93042200  SEARS/DRYER
Kenmore 417.93042201  SEARS/DRYER
Kenmore 417.93052200  SEARS/DRYER
Kenmore 417.93052201  SEARS/DRYER
Kenmore 417.93142200  SEARS/DRYER
Kenmore 417.93142201  SEARS/DRYER
Kenmore 417.93702200  LAUNDRY CENTER
Kenmore 417.93802200  LAUNDRY CENTER
Frigidaire 41739012890 Frg(v0) / Washer
Frigidaire 41739012891
Frigidaire 41739022890 Frg(v0) / Washer
Frigidaire 41739022891 Frg/washer
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
  #2 (permalink)
Old 05-14-2010, 06:44 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I would think your motor is ok, and that your readings are within the sampling error limits on your meter.
Go ahead and replace the fuse, and see if that fixes things. If it continus to blow you will probably have to replace the speed control board.
Here is a service manual that will discuss your problem.
http://frigidaireservicetips.com/pdf...ionWashers.pdf
__________________
  #3 (permalink)
Old 05-14-2010, 08:59 AM
Junior Member
Default
Thanks for the service manual. Speed control board is on order. Will let you know how installation goes. I did replace the fuse and it blew. Areas of discoloration on printed circuit board. Thanks again............Jay
  #4 (permalink)
Old 05-14-2010, 11:47 AM
Senior Expert
APP Volunteer
Default
Sounds very much like a new speed control board will fix things, let us know how it turns out.
__________________
  #5 (permalink)
Old 05-16-2010, 02:00 PM
Junior Member
Default
Quote:
Received the 'used' board from ******** yesterday. Installed it today (Sunday) and it's going through the cycling as I write. So far so good.
After receiving diagnosis' of door switch and timer, I've finally REALLY discovered the problem.
Thanks for you help. I suggest that anyone else having this problem, BEFORE anything else, pull the circuit board and check if for signs of overheating (charring). Once the back panel is off, two electrical connectors and two screws are all required to remove.
  #6 (permalink)
Old 05-16-2010, 02:31 PM
Senior Expert
APP Volunteer
Default
Great, glad to hear that it is working. The speed control board on that model is a real weak link, and fails regularly.
Thanks for the update and good luck going forward.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
erractic agitator spin bword Washer Repair 21 03-23-2010 08:58 PM
GE Washer Agitator will not spin tycates Washer Repair 4 07-23-2009 01:39 PM
Agitator will spin but not agitate Stormin Norman Washer Repair 1 06-29-2009 05:36 PM
Agitator and Spin noisy wlear Washer Repair 2 01-19-2009 08:22 PM
GE Washer Agitator won't spin dockworkerdonny Washer Repair 1 03-25-2008 05:54 PM
