Discuss
Smelly Washer
 in
Washer Repair
I have taken this machine apart down to the tub at on 8 occaisions to clean gunk that smells real
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Smelly Washer
  #1 (permalink)
Old 07-02-2008, 04:52 AM
MJM MJM is offline
Junior Member
MJM is on a distinguished road
Default Smelly Washer
Model Number: LSR8233EQO   Brand: Whirlpool   Age: 5 - 10 years
I have taken this machine apart down to the tub at on 8 occaisions to clean gunk that smells real bad between the 2 walls of drum..is there something not operating right for this condition to be occurring?it is isolated to top 1/3 of tub,and is in small laundry room..so I have to stay on top of keeping it clean..any help or ideas would be fgreatly appreciated....thanks,MJ
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-05-2008, 09:05 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
MJM,
It was recommended by all manufacturer to clean washers on regular basis. You can use regular white vinegar - one gallon per tub full of hot water, run through a complete cycle. Do it once a month.
I'm using for my washer the cleaning stuff called Washer Magic. It works for me very good.
For your future references here are the break down diagrams for the Whirlpool washer Model LSR8233EQ0
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 07-05-2008, 11:36 PM
MJM MJM is offline
Junior Member
Default
i have taken it apart five or 6 times,in past 2 yrs..I was wondering if this kind of dirty condition is common,and how to clean it more easily..ihave to remove entire shell,pull off upper basket ring to get my hands down in liner to scrub off the crud.it seems to just crud up in that laast 1/3 of the liner tub..any other ideas on how to go about it easier,especially since I have to do it so frequenthly...thanks
  #4 (permalink)
Old 07-07-2008, 01:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The problem you're having has nothing to do with the washer. This is a chemical problem, not a mechanical.
Try to use a different detergent and decrease amount of it. Do the regular chemical (vinegar or Washer Magic) cleaning and I believe, you'll see improvement.
__________________
  #5 (permalink)
Old 07-07-2008, 01:43 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
To add my 2 cents, I notice and get complaints frequently on this issue, most the complaints come from people that do not use bleach frequently.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #6 (permalink)
Old 07-23-2008, 04:08 PM
exponent exponent is offline
Junior Member
exponent is on a distinguished road
I have a client that sells Smelly Washer Cleaner. It is a powder that you put in the machine that cleans the washer. He gets rave reviews. You might check it out.
Good luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
