AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Neptune doorlock wax motor works, but doesn't actuate lock light microswitch
Hi, I have a question. Hope I reached the correct email address.
On my Neptune, when I energize the door lock wax motor (120v 60hz), the black plunger extends outward normally, but the far end doesn't quite reach far enough to actuate the microswitch. The schematic id's that switch as operating the door lock light.
Is the light all it does? Or does the failure of this switch to close also cause the logic board to take further action, such as shutting down the spin cycle? Our symptom is sometimes the drum doesn't drain fully. Not all the time, just sometimes. The microswitch is very close to "making", so I could see it working sometimes, and sometimes not. Just don't know if the logic board JUST turns on the light, or does it do more than that.
Also, I have the 35w pump motor. I'm seriously thinking of ordering the 80w pump just to make sure that's not the problem. No, the pump isn't clogged at all. Already took that apart. And the washer isn't in a basement, so the wall drain is only about 36" high. Not too much of a rise.
Thanks, Rick
Washer Repair
