| » GE washer will fill and drain but no spin/agitate |
You are welcome. I'm glad it's up and running.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Sometimes it spins real slow. Now it won't even agitate. I don't see a green light flashing even in total darkness. WPRE6150k2wt is the model number. After reading everything it seems to be the motor. But why would it sometimes spin real slow???
What is the part # for the motor and fuse on the r/w wire? |
Quote:
scobby98, Did you do this test? - The fusible link Part number: AP4390012 Gene.
__________________
Quote:
thank you!!! |
just thought id put my two cents in i have seen time and time again were these idiots charge for a motor only to find out its nothing more than a open fuse link. think their going to put the origional motor back on heck no they will tell you it was the motor keep it and sell it again to the next customer. Look through the left side for the green light if no steady light or bliking light then 100% the fuse link is open
Quote:
A such time intervals for the status LED is very unusual and is not listed as an error code. If it's normal then it should blink 1 second On & 1 second Off in standby, and 1/2 sec On & 1/2 sec Off while it's running. Otherwise the LED should blink a number of time (depends on an error detected) for a 1/4 of second each and then Off for the reminder of a 6 seconds period. Gene.
__________________
The signal LED flashing 6 times with free motor and tubs leading to a bad motor. The mode shifter coils test result shows it to be bad as well. So both the motor/inverter assembly and the mode shifter assembly have to be replaced.
- The motor/inverter assembly Part number: WH20X10058 - The mode shifter assembly Part number: WH38X10017 Here are the breakdown diagrams and Replacement parts for General Electric WLRR5000G0WW Washer | AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| GE washer will fill and drain but no spin/agitate | Montana_Pete | Washer Repair | 10 | 09-22-2011 04:48 PM |
| Washer will fill, drain, spin but won't agitate | tmatsick | Washer Repair | 8 | 05-11-2011 03:05 PM |
| Washer will fill & agitate, won't spin or drain | legomom0701 | Washer Repair | 2 | 06-21-2010 11:11 AM |
| Washer want to agitate or spin but will fill up with water and will drain? | robuga | Washer Repair | 2 | 01-01-2010 01:52 PM |
| Washer will fill and agitate but not spin/drain at all | Narapni | Washer Repair | 0 | 11-03-2007 01:20 AM |
