Discuss
GE washer will fill and drain but no spin/agitate
 in
Washer Repair
Originally Posted by johny2thumbs Im unable to begin a new posting, so Im jumping in on this one.. My model
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer will fill and drain but no spin/agitate
  #61 (permalink)
Old 04-07-2011, 12:24 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
My model wwse5240g0ww is a no agitate spin
I did a continuity test from wall plug ends to motor plug
I have powers and ground present at motor
It fills and drains
The 2 prong to device on shaft Ohm's out good
Good LEDs with no fault codes present
GE reset = nothing..
Thanks in advance for your time and talent.
You may want to check the inline fuse for continuity. The instructions are attached.
- The fuse link Part number: AP4390012
Here are the breakdown diagrams and Replacement parts for General Electric WWSE5240G0WW Washer | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #62 (permalink)
Old 04-07-2011, 06:06 PM
Junior Member
johny2thumbs is on a distinguished road
Default A stroke of luck!
Hi Gene,
thanks for the recommendation about the fuse,
I assume it is good as I have power present at the motor at orange and red white wires.
The good news is when leaving home Depot I saw a scratch and dent washer for $150 !!! so I packes it uo got it home swapped out the top/lid assembly and away we go. .
I bought an extended warrant and will use a seperate ground wire and get a surge protector for it too.
nMean while on my porch sits a mystery. Ill check the low voltage side
before I chuck it,, seems I should have gotten more than 4 years out of it.. Thanks again Gene! Your the man!!
  #63 (permalink)
Old 04-08-2011, 09:53 PM
Junior Member
plantlady64 is on a distinguished road
Default GE WASHER won't spin
My washer is a GE but the model number is WDSR2080D8WW.My washer washes and drains but won't spin. Could mine have the same fuse problem? Or do you think mine could be a timer problem.The belt is in great shape. My washer is also 5 years old. Thanks Carla.
  #64 (permalink)
Old 04-11-2011, 02:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Carla,
Your washer is very different. Does the motor run when it comes to spin?
Here are the breakdown diagrams and Replacement parts for General Electric WDSR2080D8WW Washer | AppliancePartsPros.com
__________________
  #65 (permalink)
Old 04-12-2011, 07:43 AM
Junior Member
Default
yes it runs it goes thru all cycles just won't spin out clothes.makes the noise like it wants to spin but don't.then finishes it't cycle.it didn't even smell hot when it did it.
  #66 (permalink)
Old 04-12-2011, 07:49 AM
Junior Member
Default Gene
It goes thru all cycles. It just won't spin. It sounds like it wants to but the clothes are soaked. There is no smell at the end of the cycles either.Like a hot smell
  #67 (permalink)
Old 04-12-2011, 10:01 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Remove the front panel by pushing in the release tabs under each side of the front panel.
When the washer is in spin, see if the tranny pulley is turning.
__________________
  #68 (permalink)
Old 06-12-2011, 03:22 PM
Junior Member
Xdriver is on a distinguished road
Default Is it the motor?
I have a Ge top load washer model number wpre6150k2wt that pumps out water but does not agitate or spin. I have tested the lid switch with my ohm meter between the plug and the gray wire on the motor (left bank of wires, the one opposite the green) and it has continuity.
I tested the far right bank of wires and the #4-5 and #3-5 both have 12VDC
The 2 wire plug with red and yellow have about 98ohm
I have tried resetting the controller board and do not see any flashing green lights.
Does this mean my motor is bad, if it does mean this, my motor part number is 175D5106G057 and I am unable to find it on your site. Please help. Thanks so much.
  #69 (permalink)
Old 06-13-2011, 06:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Xdriver,
Sounds like the problem is a bad in line fuse. Use the instructions posted earlier in this thread, addressed to johny2thumbs to locate it.
__________________
  #70 (permalink)
Old 06-13-2011, 07:06 PM
Junior Member
Default Inline fuse
I forgot to mention that I tested the inline fuse and that is also fine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer will fill and drain but no spin/agitate Montana_Pete Washer Repair 10 09-22-2011 04:48 PM
Washer will fill, drain, spin but won't agitate tmatsick Washer Repair 8 05-11-2011 03:05 PM
Washer will fill & agitate, won't spin or drain legomom0701 Washer Repair 2 06-21-2010 11:11 AM
Washer want to agitate or spin but will fill up with water and will drain? robuga Washer Repair 2 01-01-2010 01:52 PM
Washer will fill and agitate but not spin/drain at all Narapni Washer Repair 0 11-03-2007 01:20 AM
