Discuss
GE washer will fill and drain but no spin/agitate
 in
Washer Repair
The LED blinks four times when a mode shifter error is detected. Try to reset the error code. Unplug the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer will fill and drain but no spin/agitate
  #51 (permalink)
Old 01-06-2011, 01:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Try to reset the error code. Unplug the washer for a few minutes. Reconnect the power and open and close the lid 10 times within 12 seconds.
If it would not help then remove the shifter coil plug (the only plug with the two wires) from the inverter and check the resistance across these two wires. Normal reading suppose to be about 98 Ohms.
If the coil is open, the mode shifter assembly must be replaced.
If the reading is correct, replace the motor assembly. for some models the motor assembly has to be replaced together with the mode shifter assembly.
If you need the correct part numbers, post the complete model number of the washer and the motor part number from the motor inverter top cover. If there are no labels, check the label on the motor itself.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #52 (permalink)
Old 02-24-2011, 06:58 PM
Junior Member
j_true7@yahoo.com is on a distinguished road
Default
Gene,
I have a GE model WHDRR41861WW. The washer would not agitate or spin, but it would pump water. I did not see the LED so I replaced the fuse. Now I see the LED clearly and there are no fault codes after running it thru one cycle. The washer still will not agitate or spin. Any recommendations?
  #53 (permalink)
Old 02-25-2011, 06:49 AM
Junior Member
bigubomb is on a distinguished road
Default
have a ge model WLRR5000GOWW washer that i replaced the shifter coil on. I went through all the steps to check it and all checks confirmed the shifter coil was bad. Now the winky blinky blinks 6 times saying the motor is bad. I was just curious if it is common for the motor and shifter coil to go out at the same time.
Thanks for the help
  #54 (permalink)
Old 02-25-2011, 03:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by j_true7@yahoo.com View Post
Gene,
Bypass the lid switch and run the washer. Make sure the wires from the lid switch are not pinched or broken.
Here are the breakdown diagrams and Replacement parts for General Electric WHDRR418G0WW Washer | AppliancePartsPros.com
__________________
  #55 (permalink)
Old 02-25-2011, 03:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Thanks for the help
Unfortunately a bad shifter coil can cause a damage to the motor inverter.
Before you replace the motor do the following:
Try to clear the error code: disconnect the power for a few minutes, reconnect the power and open and close the lid 10 times within 12 seconds.
Remove the belt and turn the large pulley. It should move freely in both directions. If it's not then you may want to make sure there is nothing stuck between the inner & outer tubs and the mode shifter is installed properly.
- The motor assembly Part number: AP4536552
Here are the breakdown diagrams and Replacement parts for General Electric WLRR5000G0WW Washer | AppliancePartsPros.com
__________________
  #56 (permalink)
Old 02-25-2011, 07:06 PM
Junior Member
Default
[quote=Gene;362809]Bypass the lid switch and run the washer. Make sure the wires from the lid switch are not pinched or broken.
Can you provide some instructions on how to bypass the lid switch?
  #57 (permalink)
Old 02-25-2011, 07:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Unplug the washer. Cut the wires connected to the lid switch about 10" from the lid switch and connect them together. Make sure it's not touching any metal parts. Plug the washer back and give it a try.
__________________
  #58 (permalink)
Old 02-25-2011, 09:49 PM
Junior Member
Default
Quote:
That fixed the washing machine. Thanks for the help.
  #59 (permalink)
Old 02-26-2011, 03:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome.
I want you to know that this fix (bypass) is just temporary, mostly for the diagnosis only. You can not use the washer in such condition. The lid switch has to be replaced.
- The lid switch Part number: AP3968471
__________________
  #60 (permalink)
Old 04-06-2011, 08:57 PM
Junior Member
johny2thumbs is on a distinguished road
Default I have the same issue but all diagnostic test check out.
[quote=Gene;363838]You are welcome.
Im unable to begin a new posting, so Im jumping in on this one..
My model wwse5240g0ww is a no agitate spin
I did a continuity test from wall plug ends to motor plug
I have powers and ground present at motor
It fills and drains
The 2 prong to device on shaft Ohm's out good
Good LEDs with no fault codes present
GE reset = nothing..
Thanks in advance for your time and talent.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer will fill and drain but no spin/agitate Montana_Pete Washer Repair 10 09-22-2011 04:48 PM
Washer will fill, drain, spin but won't agitate tmatsick Washer Repair 8 05-11-2011 03:05 PM
Washer will fill & agitate, won't spin or drain legomom0701 Washer Repair 2 06-21-2010 11:11 AM
Washer want to agitate or spin but will fill up with water and will drain? robuga Washer Repair 2 01-01-2010 01:52 PM
Washer will fill and agitate but not spin/drain at all Narapni Washer Repair 0 11-03-2007 01:20 AM
