Discuss
GE washer will fill and drain but no spin/agitate
 in
Washer Repair
Originally Posted by Gene grau0201, According to the model number you posted this washer is a top load. Gene. You're
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer will fill and drain but no spin/agitate
  #21 (permalink)
Old 12-14-2010, 03:50 PM
Junior Member
grau0201 is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
grau0201,
You're right, it is a top loader, sometimes I'm pretty dense
Ads By Google
  #22 (permalink)
Old 12-15-2010, 02:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Richie,
If there is the correct voltage to the motor inverter and the motor is dead, the motor is the culprit.
- The motor Part number: AP4511844
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #23 (permalink)
Old 12-18-2010, 01:20 PM
Junior Member
ryn1127 is on a distinguished road
Default
Gene,
First, I want to thank you for helping everone out on here, I have already read many of your suggestions and have checked a few things. I have a GE washer model #WCSR4170G2WW that will not spin or agitate. Yesterday the machine started bouncing pretty bad as I had an un-even load in it, and now it is not working properly. The washer fills and drains, but just clicks through the rest of the cycle and does nothing else. I have the front cover off and see the green LED light flashing. The light appears to be blink approximately 1 second on 1 second off. The belt is intact and spins the tub easily (by hand). Any advice would be greatly appreciated.
Thanks, Ryan
  #24 (permalink)
Old 12-19-2010, 04:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Ryan,
The first thing I would do is reset the washer controls.
Unplug the washer for a few minutes. Reconnect the power and open & close the lid 10 times within 12 seconds. Post the results.
__________________
  #25 (permalink)
Old 12-20-2010, 06:33 AM
Junior Member
Default
Gene,
I followed the procedure a couple times to ensure I got it right, but unfortunately do not see any change whatsoever. Same symptoms as listed above. Thanks again, Ryan.
  #26 (permalink)
Old 12-20-2010, 08:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Ryan,
Check the mode shifter coil. Remove the plug C7 (the second plug from the right side with the two wires - red & yellow) and measure the resistance across these wires. It suppose to be about 98 Ohms.
__________________
  #27 (permalink)
Old 12-21-2010, 10:48 AM
Junior Member
Default
Gene,
I measured the resistance between the two wires you suggested and I am getting right around 67 ohms regardless if the washer is on or off. Hope this information tells you something.
Thanks again,
Ryan
  #28 (permalink)
Old 12-21-2010, 02:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Ryan,
Check and post the part number on the top inverter cover. If there are no numbers, check the motor label. It should look similar to 175D5106G***.
__________________
  #29 (permalink)
Old 12-21-2010, 03:30 PM
Junior Member
Default
Gene,
The label on the motor has the number 175D5106G036 on it.
Ryan
  #30 (permalink)
Old 12-21-2010, 03:51 PM
Senior Member
applianceman is on a distinguished road
Default
Check the lid switch. On the motor there are four plugs. Disconnect the plug farthest left. Place one lead of your ohmmeter on the line terminal of the power cord and the other on the orange (may not be orange) wire of the motor plug. It should be the wire on the far end directly opposite of the green wire. You should get continuity across this with the lid closed and it should be open when the lid is opened.
There is picture on this page that shows what I am talking about. HydroWave GE Washer Repair Guide
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer will fill and drain but no spin/agitate Montana_Pete Washer Repair 10 09-22-2011 04:48 PM
Washer will fill, drain, spin but won't agitate tmatsick Washer Repair 8 05-11-2011 03:05 PM
Washer will fill & agitate, won't spin or drain legomom0701 Washer Repair 2 06-21-2010 11:11 AM
Washer want to agitate or spin but will fill up with water and will drain? robuga Washer Repair 2 01-01-2010 01:52 PM
Washer will fill and agitate but not spin/drain at all Narapni Washer Repair 0 11-03-2007 01:20 AM
