Discuss
GE washer will fill and drain but no spin/agitate
 in
Washer Repair
My Whirlpool washer did the same thing and I was told it was the motor coupling. I took the old
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer will fill and drain but no spin/agitate
  #11 (permalink)
Old 07-08-2008, 11:37 AM
Junior Member
kfowkes5 is on a distinguished road
Default
My Whirlpool washer did the same thing and I was told it was the motor coupling. I took the old one off and it was broken, new one was 25.00 at a local appliance repair shop, cheaper online though. Don't know if this would be the same for fix for a GE appliance.
  #12 (permalink)
Old 07-08-2008, 12:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
GE and Whirlpool washers are absolutely different.
What is the model number of your washer?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #13 (permalink)
Old 06-20-2010, 09:40 PM
Junior Member
girlwhowantstofix is on a distinguished road
Default Gene- please help!
dwhdrr418goww model
GE lg capacity washer. same deal wan't spin or agitate. took off bottom and that big belt looks good. took off front and led light says motor is good- green light flashes on and off every sec.
seems like the bucket moves around a lot, but maybe that is normal... doesn't look like there are any loose pieces. it makes a noise during the wash cycle and spin cycle like it is trying, but just not happening... seems like it is not connected right to the bowl but this is probably not the case
  #14 (permalink)
Old 06-20-2010, 10:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by girlwhowantstofix View Post
dwhdrr418goww model
The first thing I would do is check the lid switch for continuity.
__________________
  #15 (permalink)
Old 06-20-2010, 10:43 PM
Junior Member
Default
how do i do this? it is a magnet type or something...
has some type of sensor... i am no guru at this but would love to figure all this out! Thanks!!
just read an article written about testing continuity... i don't have meters or anything, so this may be beyond what i can do here! if so, thank you anyway!!
  #16 (permalink)
Old 06-21-2010, 11:01 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Does it drain?
If it does, remove the front panel and run the washer to see if the motor runs.
__________________
  #17 (permalink)
Old 06-21-2010, 11:10 AM
Junior Member
jeanfix is on a distinguished road
Default
front loaders only last...5-6 yrs...and if center leaks...a $330 repair...just a few things I read about... everytime I went to the store to pick out a model...i'd come home and read a terrible blog. The Conventional machines are fine...unless you live in water saving states...
  #18 (permalink)
Old 12-13-2010, 07:33 PM
Junior Member
grau0201 is on a distinguished road
Default GE Front Loader won't spin/agitate
Looking for assistance...
Working with a GE WLSR3000G0WW front loader that won't spin or agitate. I get no LED lights on the motor inverter. I got 120 vac on the white/red line, 120 vac on the black/red line and 120 vac on the dk blue line. Continuity is present at the lid switch. I'm almost 100% positive I have a busted motor. Is there anything else I can check before I commit? Any assistance would be greatly appreciated.
Thanks, Richie
  #19 (permalink)
Old 12-14-2010, 02:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Gene View Post
...If the LED is not lit then check the harness fuse which is wired in the neutral side of the line. The fuse is wrapped in the motor harness located along the right side of the cabinet. The fused wire is connected to the C2-3 pin on the inverter. If the fuse is open , the motor would not work.
- The part number for the fuse link is AP3995512
grau0201,
According to the model number you posted this washer is a top load.
Have you tested the fuse as described above?
Here are the breakdown diagrams and Replacement parts for General Electric WLSR3000G0WW Washer | AppliancePartsPros.com
__________________
  #20 (permalink)
Old 12-14-2010, 03:47 PM
Junior Member
Default
grau0201,
Gene, thanks for the reply...
I inspected the fuselink like you had indicated in previous posts and it appears to be intact. 120 vac is present on the white/red wire which I believe is input power to the motor. The motor doesn't make a sound and I didn't see a light which lead me to believe the motor was bad. Thoughts?
Richie
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer will fill and drain but no spin/agitate Montana_Pete Washer Repair 10 09-22-2011 04:48 PM
Washer will fill, drain, spin but won't agitate tmatsick Washer Repair 8 05-11-2011 03:05 PM
Washer will fill & agitate, won't spin or drain legomom0701 Washer Repair 2 06-21-2010 11:11 AM
Washer want to agitate or spin but will fill up with water and will drain? robuga Washer Repair 2 01-01-2010 01:52 PM
Washer will fill and agitate but not spin/drain at all Narapni Washer Repair 0 11-03-2007 01:20 AM
