Discuss
GE washer will fill and drain but no spin/agitate
 in
Washer Repair
Thanks for the reply, yeah it runs through everything like it is suppose to but during agitation nothing happens.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer will fill and drain but no spin/agitate
  #121 (permalink)
Old 03-02-2013, 10:14 PM
Junior Member
zsewell75 is on a distinguished road
Default
  #122 (permalink)
Old 04-14-2013, 09:30 PM
Junior Member
fdmaatouk is on a distinguished road
Default
I opened the front panel and counted the light flashing. it flashes for 6 times then stops flashing for 4 seconds then flash again for 6 seconds. what does that mean? where is the defect?
Thank you
  #123 (permalink)
Old 09-01-2013, 02:22 PM
Junior Member
wseda22 is on a distinguished road
Default GE Washer GCWN5050M0WS
Hello everyone,
I have a GE Washer model # GCWN5050M0WS and I am seeing the error code of 6 flashes. I put my multimeter to the mode shifter and it read 68 ohms, open. It seems as if the motor isn't even engaging. I'm unsure if it is the motor, the mode shifter, or both.
Any suggestions on how I could further isolate the issue? Thanks.
-Willie
  #124 (permalink)
Old 09-03-2013, 06:50 PM
Junior Member
fillthebarman is on a distinguished road
Default Ge washer.
I had a customer having the exact problem on a 1 1/2 year old ge washer . We looked for fuse but none to be found. Doesn't show one on schematic. Could never get it to start after filling. My educated guess the problem is the board on the motor.
  #125 (permalink)
Old 11-16-2013, 11:59 AM
Junior Member
bokersmith is on a distinguished road
Default ge washer wjsr4160g2ww wont go into agitation mode;
i've read a couple posts with similar problems. got the top off and see a panel with a light. nothing flashing but the washer fills, clicks and keeps moving through cycle w/o agitating. the belt looks new and is firmly in place. what next? thank you
  #126 (permalink)
Old 11-16-2013, 12:15 PM
Senior Member
Appliance Ninja is on a distinguished road
Default
The light that will be flashing is under the cover on the top of the motor. Count the number of flashes in between pauses and then post that number, please.
  #127 (permalink)
Old 07-07-2014, 09:35 AM
Junior Member
deeingmire is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
Remove the front panel and locate the green LED on the right side on top of the motor on the inverter plate. Monitor and calculate number of flashes during a 6 seconds period. Post the result.
This is one of the last GE models and it should be good as long as you use it properly. You'll have more troubles with most of flrontloaders.
I found the led light and it is flashing 4 times.what should I do?
  #128 (permalink)
Old 07-07-2014, 09:41 AM
Junior Member
Default
Indicater light flashes 4 times
  #129 (permalink)
Old 02-01-2015, 07:09 PM
Junior Member
rgray107918 is on a distinguished road
Default lid switch sparked
After reading through posts, I attempted to bypass the lid switch. I must not have taped the wires well enough and they contacted the machine body, sparled, and now I have no operation at all.
Initially, I was getting 7 flashes from led, so I was going to bypass the switch, but now I need to know what I might have messed up to make all operation stop.
Are there any main fuses I should check?
  #130 (permalink)
Old 02-02-2015, 06:28 AM
Senior Member
applianceman is on a distinguished road
Default
Some models have a fuse for the motor that you may have blown. If the light that was blinking was red you donít have a fuse. If it was green you have a fuse. If the fuse is blown the light will no longer blink. The fuse is an in-line fuse in the group of wires to the right of the tub. If the fuse isnít bad or you donít have a fuse my guess is your motor is bad. (This is especially true if the light no longer blinks) however the short could have also damaged the control.
This page talks about how to check the fuse HydroWave GE Washer Repair Guide
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer will fill and drain but no spin/agitate Montana_Pete Washer Repair 10 09-22-2011 04:48 PM
Washer will fill, drain, spin but won't agitate tmatsick Washer Repair 8 05-11-2011 03:05 PM
Washer will fill & agitate, won't spin or drain legomom0701 Washer Repair 2 06-21-2010 11:11 AM
Washer want to agitate or spin but will fill up with water and will drain? robuga Washer Repair 2 01-01-2010 01:52 PM
Washer will fill and agitate but not spin/drain at all Narapni Washer Repair 0 11-03-2007 01:20 AM
