Discuss
GE washer will fill and drain but no spin/agitate
 in
Washer Repair
Check for 120vac on the leftmost connector of the inverter board. You should have 120vac between wht/red and red/blk as
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer will fill and drain but no spin/agitate
  #111 (permalink)
Old 01-09-2013, 08:03 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Check for 120vac on the leftmost connector of the inverter board. You should have 120vac between wht/red and red/blk as well as between wht/red and orn. If ok, and you don't see the flashing green LED, the inverter is bad. If the motor has been replaced within the last couple years, the new style motor has a flap on the right side. You must lift the flap to see the LED which is now red, vice green. The inverter is not repairable/replaceable, you must replace the whole motor/inverter unit. New motors come with a jumper to replace the fuse which must be removed. Make sure you get the right motor/inverter, there are about 5 different versions and they are not interchangeable.
Eric
Ads By Google
  #112 (permalink)
Old 01-09-2013, 10:19 AM
Junior Member
jlethert is on a distinguished road
Default
There is no visible LED on this board? I have the board off and cover off and do not see led anywhere? cover over inverter has a stamp of july 2006, is it possible aftermarket motor with no led? Is there another way to check codes, I have read about "service mode" is there another way to diagnose?
  #113 (permalink)
Old 01-09-2013, 11:01 AM
Expert
APP Volunteer
Default
Can you provide a clear picture of the top of the circuit board? No aftermarket replacements that I'm aware of. Service manual shows LED and codes.
Eric
  #114 (permalink)
Old 01-09-2013, 02:19 PM
Junior Member
Default
thanks, did not get picture, will post later, but motor is coming up bad, so going to replace and cross my fingers that is it, thanks for the help! Joe
  #115 (permalink)
Old 01-10-2013, 11:46 AM
Junior Member
bobmack12 is on a distinguished road
Default
I have the same problem, the Led flashes green, for 1 sec, then off for 1 sec, i cannot find what the LED flashing suggests what is defective?
  #116 (permalink)
Old 01-10-2013, 01:24 PM
Expert
APP Volunteer
Default
Flashing continuously 1 second on/off is normal, no error code. If you are seeking advice, please start a new topic with your symptoms and washer model number.
Eric
  #117 (permalink)
Old 01-29-2013, 05:07 PM
Junior Member
JavaG66 is on a distinguished road
Default
Quote:
check the harness fuse which is wired in the neutral side of the line. The fuse is wrapped in the motor harness located along the right side of the cabinet.
Read more: GE washer will fill and drain but no spin/agitate
http://forum.appliancepartspros.com
Is there a similar fuseable link for a WLSE3150A0WW? I couldn't it find on on the White/Red wire up front; maybe in the control section? Same symptoms. I have a bad motor, but I wanted to make sure I was getting current down to it before purchasing another one. Thanks!
  #118 (permalink)
Old 01-29-2013, 05:34 PM
Expert
APP Volunteer
Default
No fuse, totally different washer design.
Eric
  #119 (permalink)
Old 03-02-2013, 03:25 PM
Junior Member
zsewell75 is on a distinguished road
Default Washer won't agitate
I have a GE Washer Model # WHDSR209D5WW. It won't agitate I followed the steps to reset the motor and then ran a small load. The only thing that happens is a buzzing sound but it is coming behind cycle selector knob. It runs through the rest of the cycle fine. Any help would be great!
  #120 (permalink)
Old 03-02-2013, 06:07 PM
Expert
APP Volunteer
Default
The reset procedure does not apply to your washer model. Does the washer fill with water? If it fills, when it stops filling, does the timer advance on it's own? If it doesn't, you likely have a bad water level switch. If it does, it's likely a bad timer. There is always the possiblity of faulty wiring/connectors between these devices.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer will fill and drain but no spin/agitate Montana_Pete Washer Repair 10 09-22-2011 04:48 PM
Washer will fill, drain, spin but won't agitate tmatsick Washer Repair 8 05-11-2011 03:05 PM
Washer will fill & agitate, won't spin or drain legomom0701 Washer Repair 2 06-21-2010 11:11 AM
Washer want to agitate or spin but will fill up with water and will drain? robuga Washer Repair 2 01-01-2010 01:52 PM
Washer will fill and agitate but not spin/drain at all Narapni Washer Repair 0 11-03-2007 01:20 AM
