Discuss
GE washer will fill and drain but no spin/agitate
 in
Washer Repair
Thanks Gene !! Ads By Google
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer will fill and drain but no spin/agitate
  #91 (permalink)
Old 05-01-2012, 06:38 PM
Junior Member
Native Texan is on a distinguished road
Default
Thanks Gene !!
Ads By Google
  #92 (permalink)
Old 05-02-2012, 01:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #93 (permalink)
Old 07-02-2012, 04:09 PM
Junior Member
gutrunner is on a distinguished road
Default Same problem
Sir,
I have tried just about every check listed in this thread. The motor shows no LED light. It has 120V across back/red and white/red. Even jumped across fuse . Tried reset multiple times. Any other ideas. Washer is 2 years old. Have tech and $79 bill for for checking problem coming tomorrow. Thanks in advance.
  #94 (permalink)
Old 07-03-2012, 05:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by gutrunner View Post
Sir,
If there is no LED at all then the motor most likely is bad.
__________________
  #95 (permalink)
Old 07-06-2012, 08:10 AM
Junior Member
Thumbs up
Thanks for reply. GE tech checked and said same thing. Bought another machine, but not GE. GE tech said if I did choose to repair, remove fusable link completely. He said they now bypass that on repair calls. Thanks again for reply and information available on your website.
  #96 (permalink)
Old 07-10-2012, 08:07 AM
Junior Member
gbean22 is on a distinguished road
Default GE Washer WJSR4160G0WW
Gene,
My washer recently stopped agitating and spinning. Seems to fill fine and drain. Bypassed the lid switch, no change, checked the pressure switch, seems to working, and checked the agitator coupling. What else can we do??
  #97 (permalink)
Old 07-10-2012, 04:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the front panel and check the status of the LED on top of the motor. Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric WJSR4160G0WW Washer | AppliancePartsPros.com
__________________
  #98 (permalink)
Old 07-10-2012, 05:53 PM
Junior Member
Default
Do not see a led light anywhere. So I'm assuming its not on.
  #99 (permalink)
Old 07-10-2012, 08:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Check the fuse.
__________________
  #100 (permalink)
Old 07-11-2012, 03:41 AM
Junior Member
Default
Did that. Can you tell me how much a motor would cost?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer will fill and drain but no spin/agitate Montana_Pete Washer Repair 10 09-22-2011 04:48 PM
Washer will fill, drain, spin but won't agitate tmatsick Washer Repair 8 05-11-2011 03:05 PM
Washer will fill & agitate, won't spin or drain legomom0701 Washer Repair 2 06-21-2010 11:11 AM
Washer want to agitate or spin but will fill up with water and will drain? robuga Washer Repair 2 01-01-2010 01:52 PM
Washer will fill and agitate but not spin/drain at all Narapni Washer Repair 0 11-03-2007 01:20 AM
