our machine will not drain. i have checked the drain hose and it's clear. i can blow air from it to the drum.
when i took the wires from the pump and turned it on, i got 120v to the wires, does that sound like the pump is bad? it really doesn't make any noise when trying to pump, just a faint humming noise.
does this sound like it will be pump?
I have a part number for a replacement but want to make sure this is want i need to purchase.
AP3160348
If the pump is getting power but not turning when it is supposed to be draining it is most likely the pump. If you buy from this site and it does not fix it you can probably return it, see the returns policy.
