| » Washer won't stop filling and overflows |
Model Number: lsn1000jqo Brand: Whirlpool Age: 5 - 10 years
My washer does not stop filling. Can anyone tell me the name of the part I need to order to fix this problem? Thank you.
How did you get the water to stop? Did you turn the water off or did you pull the knob to stop the timer or did you unplug the electrical cord?
1. If you turned the water off, it could be several things, Water Level switch, Water Temperature Switch, Inlet solenoid valve or the Timer 2. If, you pulled the plug or the power off knob and the water continued to run then the water inlet solenoid valve is the culprit but there is the possibility of multiple components |
| Display Modes | |
| washer won't stop filling!!!! | dalejrmaniac | Washer Repair | 18 | 09-05-2008 05:02 PM |
| Washer will not stop filling and tub leaks | t7433 | Washer Repair | 1 | 03-13-2008 12:16 PM |
| washer won't stop filling | mnestinger | Washer Repair | 1 | 11-14-2007 12:25 PM |
| Washer will not stop filling | Mwaters583 | Washer Repair | 1 | 10-26-2007 10:59 AM |
| washer overflows,does not stop filling | cherokeedave | Washer Repair | 4 | 10-16-2007 04:38 PM |
