Discuss
does not work
 in
Washer Repair
washer does nothing does not fill with water or start Related ModelsWhirlpool LA7000XTW1 Whirlpool LA7001XSW0 Whirlpool&
Appliance Repair Forum > Appliance Repair Help > Washer Repair » does not work
  #1 (permalink)
Old 06-29-2008, 05:46 PM
moportom moportom is offline
Junior Member
moportom is on a distinguished road
Default does not work
Model Number: la7000xtw1   Brand: Whirlpool   Age: More than 10 years
Related Models
Whirlpool LA7001XTF1
Whirlpool LA7001XTG1
Whirlpool LA7001XTM1
Whirlpool LA7001XTN1
Whirlpool LA7001XTW0
Whirlpool LA7001XTW1
Whirlpool LA7005XKW0
Whirlpool LA7005XKW1
Whirlpool LA7005XMW0
Whirlpool LA7005XPW0
Whirlpool LA7005XPW1
Frigidaire LA700AXD1 Wwh(v4) / 27 " Washer
Frigidaire LA700AXD2 Wwh(v4) / 27 " Washer
Frigidaire LA700AXD3 Wwh(v3) / 27 " Washer
Frigidaire LA700AXW1 Wwh(v3) / 27 " Washer
Frigidaire LA700AXW2 Wwh(v3) / 27 " Washer
Frigidaire LA700AXW3 Wwh(v4) / 27 " Washer
Frigidaire LA700MXD1 Wwh(v6) / 27 " Washer
Frigidaire LA700MXW1 Wwh(v5) / 27 " Washer
Maytag LA702 Washer - Top Loading
Whirlpool LA7088XTF0
Whirlpool LA7088XTF1
Whirlpool LA7088XTG0
Whirlpool LA7088XTG1
Whirlpool LA7088XTM0
Whirlpool LA7088XTM1
Whirlpool LA7088XTN0
Whirlpool LA7088XTN1
Whirlpool LA7088XTW0
Whirlpool LA7088XTW1
Maytag LA710 Washer - Top Loading
Maytag LA710S Washer - Top Loading
Maytag LA712 Washer - Top Loading
Maytag LA712T Washer - Top Loading
Maytag LA7300 Washer - Top Loading
Maytag LA7400 Washer - Top Loading
Whirlpool LA7400XMW0
Whirlpool LA7400XMW1
Whirlpool LA7400XMW2
Whirlpool LA7400XMW3
Whirlpool LA7450XMW0
Whirlpool LA7450XMW1
Whirlpool LA7460XMW0
Maytag LA7500 Washer - Top Loading
Maytag LA7500S Washer - Top Loading
Maytag LA7500W Washer - Top Loading
Whirlpool LA7500XKW0
Frigidaire LA750EXD3 Wwh(v6) / Washer
Frigidaire LA750EXF3 Wwh(v7) / Washer
Frigidaire LA750EXH3 Wwh(v8) / Washer
Frigidaire LA750EXV3 Wwh(v9) / Washer
Frigidaire LA750EXW3 Wwh(v10) / Washer
Frigidaire LA750MXD1 Wwh(v2) / 27 " Washer
Frigidaire LA750MXW1 Wwh(v1) / 27 " Washer
Whirlpool LA7680XKW0
Whirlpool LA7680XKW1
Whirlpool LA7680XKW2
Whirlpool LA7680XMW0
Whirlpool LA7680XPW0
Whirlpool LA7680XPW1
Whirlpool LA7680XPW2
Whirlpool LA7680XSW0
Whirlpool LA7680XSW1
Whirlpool LA7680XTF0
Whirlpool LA7680XTF1
Whirlpool LA7680XTG0
Whirlpool LA7680XTG1
Whirlpool LA7680XTM0
Whirlpool LA7680XTM1
Whirlpool LA7680XTN0
Whirlpool LA7680XTN1
Whirlpool LA7680XTW0
Whirlpool LA7680XTW1
Whirlpool LA7681XSW0
Whirlpool LA7681XSW1
Whirlpool LA7685XKW0
Whirlpool LA7685XKW1
Whirlpool LA7685XMW0
Whirlpool LA7685XPW0
Whirlpool LA7685XPW1
Whirlpool LA7685XPW2
Whirlpool LA7700XPW0
Whirlpool LA7700XPW1
Whirlpool LA7700XPW3
Whirlpool LA7700XPW4
Whirlpool LA7700XPW5
Whirlpool LA7700XSW0
Whirlpool LA7700XWN0
Whirlpool LA7700XWW0
Whirlpool LA7780XSW0
Whirlpool LA7780XSW1
Whirlpool LA7780XSW2
Maytag LA7800 Washer - Top Loading
Whirlpool LA7800XKW0
Whirlpool LA7800XKW1
Whirlpool LA7800XKW2
Whirlpool LA7800XMW0
Whirlpool LA7800XPW0
Whirlpool LA7800XPW1
Whirlpool LA7800XSW0
Whirlpool LA7800XSW1
Whirlpool LA7800XSW2
Whirlpool LA7800XTF0
Whirlpool LA7800XTF1
Whirlpool LA7800XTG0
Whirlpool LA7800XTG1
Whirlpool LA7800XTM0
Whirlpool LA7800XTM1
Whirlpool LA7800XTN0
Whirlpool LA7800XTN1
Whirlpool LA7800XTW0
Whirlpool LA7800XTW1
Whirlpool LA7801XTF0
Whirlpool LA7801XTG0
Whirlpool LA7801XTM0
Whirlpool LA7801XTN0
Whirlpool LA7801XTW0
Whirlpool LA7805XKW0
  #2 (permalink)
Old 06-30-2008, 02:30 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Check if there is 120VAC at the power outlet. Check the power cord.
If there is nothing wrong then check for 120VAC between the "V" wire at the water level switch and neutral (remove the "V" wire from the terminal prior to test) while the timer is in "on" position.
If there is 120VAC then the water level switch is bad and has to be replaced.
If there is no 120VAC then the timer is bad and has to be replaced.
- The part number for the timer is AP2911959
- The part number for the water level switch is AP2905822
Here are the break down diagrams for the Whirlpool washer Model LA7000XTW1
__________________
  #3 (permalink)
Old 07-04-2008, 04:16 PM
Junior Member
now fills with water now but does not wash or spin
  #4 (permalink)
Old 07-05-2008, 06:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did you run any tests from the previous reply?
__________________
  #5 (permalink)
Old 07-05-2008, 06:55 PM
Junior Member
Default reply
yes now it fills with water when itgoes to next cycle it just buzzs
i can move agitator by hand but drum will not move.
  #6 (permalink)
Old 07-05-2008, 07:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the cabinet and check the motor plug and all wires to the motor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Top arm does not work sharel Dishwasher Repair 0 01-05-2008 11:24 AM
want work pccurtis Dishwasher Repair 0 11-21-2007 02:07 PM
$200 and still don't work Rakar Dishwasher Repair 2 07-27-2007 10:14 PM
