Discuss
does not work
 in
Washer Repair
washer does nothing does not fill with water or start
Appliance Repair Forum > Appliance Repair Help > Washer Repair » does not work
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-29-2008, 04:46 PM
moportom moportom is offline
Junior Member
moportom is on a distinguished road
Default does not work
Model Number: la7000xtw1   Brand: Whirlpool   Age: More than 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-30-2008, 01:30 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Check if there is 120VAC at the power outlet. Check the power cord.
If there is nothing wrong then check for 120VAC between the "V" wire at the water level switch and neutral (remove the "V" wire from the terminal prior to test) while the timer is in "on" position.
If there is 120VAC then the water level switch is bad and has to be replaced.
If there is no 120VAC then the timer is bad and has to be replaced.
- The part number for the timer is AP2911959
- The part number for the water level switch is AP2905822
Here are the break down diagrams for the Whirlpool washer Model LA7000XTW1
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 07-04-2008, 03:16 PM
Junior Member
now fills with water now but does not wash or spin
  #4 (permalink)
Old 07-05-2008, 05:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did you run any tests from the previous reply?
__________________
  #5 (permalink)
Old 07-05-2008, 05:55 PM
Junior Member
Default reply
yes now it fills with water when itgoes to next cycle it just buzzs
i can move agitator by hand but drum will not move.
  #6 (permalink)
Old 07-05-2008, 06:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the cabinet and check the motor plug and all wires to the motor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Top arm does not work sharel Dishwasher Repair 0 01-05-2008 10:24 AM
want work pccurtis Dishwasher Repair 0 11-21-2007 01:07 PM
$200 and still don't work Rakar Dishwasher Repair 2 07-27-2007 09:14 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
