Discuss
Kenmore not draining or spinning
 in
Washer Repair
Hello there! My Kenmore Washer is no longer draining nor spinning. It will aggitate at the start of the cycle
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore not draining or spinning
  #1 (permalink)
Old 06-28-2008, 01:45 PM
Junior Member
Alicornat is on a distinguished road
Default Kenmore not draining or spinning
Model Number: 20702991   Brand: Kenmore   Age: 1 - 5 years
Hello there! My Kenmore Washer is no longer draining nor spinning. It will aggitate at the start of the cycle and after where it's supposed to drain and rinse. I am wondering if it's an issue with a lid switch, but I'm not too sure as to what it's suppose to look like?
Related Models
Amana 2071.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2075B0A Ranges, Electric*
Roper 2075B1A Ranges, Electric*
Roper 2075B2A Ranges, Electric*
Amana 2085.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2089.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2090.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2090.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2090.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2091.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2092.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2092B0A Ranges, Electric*
Roper 2092B1A Ranges, Electric*
Roper 2092B2A Ranges, Electric*
Roper 2092B3A Ranges, Electric*
Amana 2094.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2095B0A Ranges, Electric*
Roper 2095B1A Ranges, Electric*
Roper 2095B2A Ranges, Electric*
Amana 210-3B ROOM AIR CONDITIONER
Hoover 2100
Roper 2101*0E Ranges, Electric*
Roper 2101*1E Ranges, Electric*
Roper 2101*2E Ranges, Electric*
Amana 21011 COMMERCIAL MICROWAVES
Amana 21016 COMMERCIAL MICROWAVES
Roper 2101W0E Ranges, Electric*
Roper 2101W1E Ranges, Electric*
Roper 2101W2E Ranges, Electric*
Roper 2102*0E Ranges, Electric*
Roper 2102*1E Ranges, Electric*
Roper 2102*2E Ranges, Electric*
Roper 2102W0E Ranges, Electric*
Roper 2102W1E Ranges, Electric*
Roper 2102W2E Ranges, Electric*
Amana 210W-3B ROOM AIR CONDITIONER
Amana 210W-3BH ROOM AIR CONDITIONER
Amana 210W-3J ROOM AIR CONDITIONER
Amana 210W-3JH ROOM AIR CONDITIONER
Amana 210W-3SP ROOM AIR CONDITIONER
Amana 210W-3SPF ROOM AIR CONDITIONER
Amana 210W-3SPFH ROOM AIR CONDITIONER
Amana 210W-3SPG ROOM AIR CONDITIONER
Amana 210W-3SPGH ROOM AIR CONDITIONER
Amana 210W-3SPH ROOM AIR CONDITIONER
Hoover 2110
Jenn-Air 21136 WALLOVEN- S/C ELE
Jenn-Air 21137 WALLOVEN- S/C ELE
Jenn-Air 21138 ELECTRIC WALL OVEN
Amana 212-2J ROOM AIR CONDITIONER
Amana 212-2J-1 ROOM AIR CONDITIONER
Amana 212-2JM ROOM AIR CONDITIONER
Amana 212-2SP ROOM AIR CONDITIONER
Amana 212-2SPF ROOM AIR CONDITIONER
Amana 212-2SPG ROOM AIR CONDITIONER
Amana 212-3J ROOM AIR CONDITIONER
Amana 212-3J-1 ROOM AIR CONDITIONER
Amana 212-3SP ROOM AIR CONDITIONER
Amana 212-3SPG ROOM AIR CONDITIONER
Hoover 2120
Hoover 2120-01
Jenn-Air 21238 WALLOVEN- S/C ELE
Jenn-Air 21239 WALLOVEN- S/C ELE
Roper 2126*0A Ranges, Electric*
Roper 2126X0A Ranges, Electric*
Frigidaire 2129A GAS RANGE
Frigidaire 2129B GAS RANGE
Frigidaire 2129C GAS RANGE
Amana 212D-3J ROOM AIR CONDITIONER
Amana 212D-3JH ROOM AIR CONDITIONER
Amana 212D-3JM ROOM AIR CONDITIONER
Amana 213-3B ROOM AIR CONDITIONER
Amana 213-3BH ROOM AIR CONDITIONER
Amana 213-3E ROOM AIR CONDITIONER
Amana 213-3F ROOM AIR CONDITIONER
Amana 213-3G ROOM AIR CONDITIONER
Amana 213-5B ROOM AIR CONDITIONER
Amana 213-5BH ROOM AIR CONDITIONER
Amana 213-5J ROOM AIR CONDITIONER
Amana 213-5JH ROOM AIR CONDITIONER
Amana 213-5SP ROOM AIR CONDITIONER
Amana 213-5SPF ROOM AIR CONDITIONER
Amana 213-5SPFH ROOM AIR CONDITIONER
Amana 213-5SPG ROOM AIR CONDITIONER
Amana 213-5SPGH ROOM AIR CONDITIONER
Amana 213-5SPH ROOM AIR CONDITIONER
Jenn-Air 21336 WALLOVEN- S/C MWAVE ELE
Roper 2136*0A Ranges, Electric*
Roper 2136X0A Ranges, Electric*
Amana 213D-3C ROOM AIR CONDITIONER
Amana 213D-3CH ROOM AIR CONDITIONER
Roper 2141*0E Ranges, Electric*
Roper 2141*1E Ranges, Electric*
Roper 2141W0E Ranges, Electric*
Roper 2141W1E Ranges, Electric*
Roper 2142*0E Ranges, Electric*
Roper 2142*1E Ranges, Electric*
Roper 2142W0E Ranges, Electric*
Roper 2142W1E Ranges, Electric*
Roper 2143*0F Ranges, Electric*
Roper 2143W0F Ranges, Electric*
Roper 2144*0F Ranges, Electric*
  #2 (permalink)
Old 06-29-2008, 04:05 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Probably a bad lid switch, just remove outer panel and replace.
__________________
  #3 (permalink)
Old 07-20-2008, 08:45 AM
Junior Member
Ginnee is on a distinguished road
Default Same Problem
Quote:
Hi
I have the same problem with the same model and it is the safety switch on the lid. You can install it yourself. Call the parts department and do it yourself, you'll save a lot of money.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Noisy While Draining/spinning LHERD Washer Repair 1 12-21-2009 04:50 PM
Washer Spinning, Not Draining nchokie Washer Repair 1 11-13-2009 05:27 PM
Washing not draining or spinning.. Jeff9353 Washer Repair 0 03-24-2009 06:49 PM
washernot draining/ spinning like it should Michelle B Washer Repair 2 03-04-2008 04:33 AM
GE Washer: Not spinning or draining Vonnie2 Washer Repair 0 11-10-2007 09:54 PM
