My washer will not spin the water out after the wash cycle. It washes the same just on spin and drain. HELP ME PLEASE!!!
Take off the front panel and check to see if the pulley turns freely or if something is caught between the tub and basket. This service manual is for a Frigidaire model that is very close to your Frigidaire made machine. http://frigidaireservicetips.com/pdfs/489_5.pdf
check the safty switch that the door triggers. If it does not make contact you will not spin
