Discuss
New Universal Motor Coupling (part no AP3963893 ) (direct drive) won't fit properly
 in
Washer Repair
The Motor coupling on our Whirlpool 5100 series disintegrated so I purchased a replacement from Star East International at Padstow
Appliance Repair Forum > Appliance Repair Help > Washer Repair » New Universal Motor Coupling (part no AP3963893 ) (direct drive) won't fit properly
  #1 (permalink)
Old 05-02-2010, 12:12 AM
Junior Member
felixq78 is on a distinguished road
Thumbs down New Universal Motor Coupling (part no AP3963893 ) (direct drive) won't fit properly
Model Number: 6LBR5132BW1   Brand: Whirlpool   Age: 1 - 5 years
The Motor coupling on our Whirlpool 5100 series disintegrated so I purchased a replacement from Star East International at Padstow in Sydney. I took the original part with me to make sure that they supplied the correct one but the assistant wasn't interested in seeing it or checking any part numbers/model numbers etc. She claimed that the new universal coupling with the metal insert was the only replacement available so I bought her BS and left. When I fitted the part I noticed that the coupling wouldn't slide all the way down the shaft because of a tiny lip on the coupling. It's still possible to reassemble the bits but there's a greater amount of pressure pushing down on the motor because of the coupling not fitting properly. Can anyone advise. Should I hunt around for the correct part or maybe just file down the lip so that the thing fits properly By the way I've been back to these people and they insist that it's the correct part even after a full description with all part numbers etc etc I won't be shopping there ever again, they've taken the attitude that because I haven't paid some tech $70 an hour to do a simple job I must be incompetent. "The part doesn't fit" no matter who is doing the job.
Ads By Google
Related Models
Whirlpool 6LBR5132BW1
Whirlpool 6LBR5132EQ0
Whirlpool 6LBR5132EQ1
Whirlpool 6LBR6233BQ0
Whirlpool 6LBR6245EQ0
Whirlpool 6LBR6245EQ1
Whirlpool 6LBR7255AN0
Whirlpool 6LBR7255AN1
Whirlpool 6LBR7255AQ0
Whirlpool 6LBR7255AQ1
Whirlpool 6LBR7255AQ2
Whirlpool 6LBR7255BN0
Whirlpool 6LBR7255BQ0
Whirlpool 6LBR7255BQ1
Whirlpool 6LBR7255BQ2
Whirlpool 6LE5700XSW0
Whirlpool 6LER5434BQ0
Whirlpool 6LER5434BQ2
Whirlpool 6LER5434BQ3
Whirlpool 6LER5434BW0
Whirlpool 6LER5434BW2
Whirlpool 6LER5434BW3
Whirlpool 6LSC8255EQ0
Whirlpool 6LSC8255EQ1
Whirlpool 6LSC9245HQ0
Whirlpool 6LSC9255AN0
Whirlpool 6LSC9255AN1
Whirlpool 6LSC9255AQ0
Whirlpool 6LSC9255AQ1
Whirlpool 6LSC9255AQ2
Whirlpool 6LSC9255AW1
Whirlpool 6LSC9255BN0
Whirlpool 6LSC9255BQ0
Whirlpool 6LSC9255BQ1
Whirlpool 6LSC9255BQ2
Whirlpool 6LSP8255AN0
Whirlpool 6LSP8255AN1
Whirlpool 6LSP8255AW0
Whirlpool 6LSP8255AW1
Whirlpool 6LSP8255AW2
Whirlpool 6LSP8255BN0
Whirlpool 6LSP8255BQ3
Whirlpool 6LSP8255BW0
Whirlpool 6LSP8255BW1
Whirlpool 6LSP8255BW2
Whirlpool 6LSR7244EQ0
Whirlpool 6LSR7244EQ1
Whirlpool 6LSS5232DQ0
Whirlpool 6LSS5232DQ1
Whirlpool 6LSS5232DQ2
Amana 6P-2AJM Room Air Conditioner
Amana 6P-2AMW Room Air Conditioner
Amana 6P-2ANM Room Air Conditioner
Amana 6P-2GM Room Air Conditioner
Amana 6P-2HM Room Air Conditioner
Amana 6P-2JM Room Air Conditioner
Amana 6P-2NH Room Air Conditioner
Amana 6P-2NHW Room Air Conditioner
Amana 6P-5G Room Air Conditioner
Amana 6P-5J Room Air Conditioner
Amana 6P2AJM Room Air Conditioner
Amana 6P5N Room Air Conditioner
Whirlpool 6RAB5132EW0
Whirlpool 6RAB5132EW1
Amana 6SPMW Room Air Conditioner
Amana 7-2B
Amana 7-2J Room Air Conditioner
Amana 7-2JM Room Air Conditioner
Amana 7-2MW Room Air Conditioner
Amana 7-2UL
Amana 7-2W Room Air Conditioner
Amana 7-5W Room Air Conditioner
Hoover 70 Frigidaire Canada/electric Range
Amana 70/05.00 Commercial Microwaves
Amana 70/05.01 Commercial Microwaves
Amana 70/05.02 Commercial Microwaves
Amana 70/05.030 Commercial Microwaves
Amana 70/05.52SS Commercial Microwaves
Amana 70/05.530SS Commercial Microwaves
Amana 70/05.540SS Commercial Microwaves
Amana 70/05.550SS Commercial Microwaves
Amana 70/05.72 Commercial Microwaves
Amana 70/05.730 Commercial Microwaves
Amana 70/05.740 Commercial Microwaves
Amana 70/08.00 Commercial Microwaves
Amana 70/08.001 Commercial Microwaves
Amana 70/08.002 Commercial Microwaves
Amana 70/08.502 Commercial Microwaves
Amana 70/09.100 Commercial Microwaves
Amana 70/09.102 Commercial Microwaves
Amana 70/09.301 Commercial Microwaves
Amana 70/10.00 Commercial Microwaves
Amana 70/10.01 Commercial Microwaves
Amana 70/10.03 Commercial Microwaves
Amana 70/10.08 Commercial Microwaves
Amana 70/10.09 Commercial Microwaves
Amana 70/10.11 Commercial Microwaves
Amana 70/15.00 Commercial Microwaves
Amana 70/15.01 Commercial Microwaves
Amana 70/15.02 Commercial Microwaves
Amana 70/15.03 Commercial Microwaves
Amana 70/20.00 Commercial Microwaves
Amana 70/20.01 Commercial Microwaves
Amana 70/20.03 Commercial Microwaves
Amana 70/20.04 Commercial Microwaves
Amana 70/20.05 Commercial Microwaves
Amana 70/20.06 Commercial Microwaves
Amana 70/20.07 Commercial Microwaves
Amana 70/20.08 Commercial Microwaves
  #2 (permalink)
Old 05-03-2010, 07:27 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Ok, even though my name is Sidney I am not familiar with Australian parts and models. However, your machine does look like the basic Whirlpool direct drive machine and yes, the motor coupling is universal and standard so the one you purchased should work.
However, there should not be a lip on the coupling so either get them to replace it or file it down. The new coupling pieces are hard to get on, what we do is put a little lubricant on the shaft and then use a socket big enough so the shaft goes into it. We put the socket on the piece and tap gently until the end of the shaft is even with the coupling piece.
Sounds like you are doing all the right things, and the problem is with your parts supplier. I would definitely register a complaint with their management.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Noisy squeaking direct drive washer; extra part? dansherman Washer Repair 1 12-10-2009 06:01 PM
replacing drive coupleing on Whirlpool direct drive washer bbuck222 Washer Repair 2 08-06-2009 07:34 AM
WHIRPOOL Motor coupling (for direct drive washers) ERNESTO Dishwasher Repair 4 12-31-2008 10:57 AM
Whirlpool Direct Drive - reasons for drive coupling failing FriarTuck Washer Repair 1 11-12-2007 01:34 PM
