Discuss
Wet Clothes after spin
 in
Washer Repair
We have an intermittent problem with our top loading, water saving Whirlpool Washer. Sometimes the clothes are soaking wet after
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Wet Clothes after spin
  #1 (permalink)
Old 06-26-2008, 08:56 PM
Junior Member
Bob V. is on a distinguished road
Default Wet Clothes after spin
Model Number: LSW0245EQ0   Brand: Whirlpool   Age: 5 - 10 years
We have an intermittent problem with our top loading, water saving Whirlpool Washer. Sometimes the clothes are soaking wet after a normal cycle, which then forces us to use the spin cycle to wring out the clothes before transfering to the dryer.
If the washer operates correctly, at the end of a normal cycle, the washer should go into spin and then spray clean water for about 10 secs, then the same water is then recirced back to the top of the tub, and sprayed for about 30 secs in an attempt to rinse the clothes. After that, the spray should stop and the water should then drain out to the sink for about another 90 secs. This should happen 6 times, for a total of 12 min, after which, a final 3 min drain will then end the cycle. The tub should be spinning the whole time.
I've watched this happen by bypassing the lid switch. The matrix on the wiring diagram gives most of these details. But when the washer "acts up", once the recirc is started, it never stops. Clean water gets added every 2 min, but then gets constantly recirced until the whole spin/rinse/drain is complete.
However, if the washer cabinet is "bumped" when it is stuck in recirc, it stops recircing and starts to drain. The new water is added right on time and the recirc then starts and gets stuck until "bumped" again.
I'm suspisious of the timer, thinking maybe the recirc contacts are getting stuck, and the "bump" is enough to release them. I dont think it is the timer motor not advancing the timer, since the cycle does advance. But based on the parts diagram on the web site, I also know that there is a bypass valve that diverts the discharge of the pump to either to the drain, or back to the tub. "Bumping" the washer could possibly be forcing the solenoid of this valve to either pull in or release to the correct state, and then stop recircing and start draining. There is also an pressure switch in the recirc line connected to an air dome, whatever that is, that a "bump" could make or break it's contacts, to allow proper operation.
I hate to just start throwing parts at this until I guess the right one. I'm inclined to think it's the bypass valve. I'd like to measure the voltage applied to it during the spin cycles, but that looks difficult to do, since the washer would have to be partially unassembled and still be able to run. Is that the correct way of troubleshooting this, or just replace the valve, reassemble the washer, and test it out to see if I guess right?
Related Models
Whirlpool LSW9245EQ0 AUTOMATIC WASHER
Whirlpool LSW9245EQ1 AUTOMATIC WASHER
Whirlpool LSW9245EQ2 AUTOMATIC WASHER
Whirlpool LSW9700PQ0 AUTOMATIC WASHER
Whirlpool LSW9700PQ1 AUTOMATIC WASHER
Whirlpool LSW9700PQ2 AUTOMATIC WASHER
Whirlpool LSW9750PW0 AUTOMATIC WASHER
Whirlpool LSW9750PW1 AUTOMATIC WASHER
Whirlpool LSW9750PW2 AUTOMATIC WASHER
Whirlpool LSW9750PW3 AUTOMATIC WASHER
 LT0810C Air Conditioner
 LT0810CR Air Conditioner
 LT1010C Air Conditioner
 LT1010CR Air Conditioner
 LT1030CR Air Conditioner
 LT1030H Air Conditioner
 LT1030HR Air Conditioner
 LT1210C Air Conditioner
 LT1210CR Air Conditioner
 LT1230C Air Conditioner
 LT1230CR Air Conditioner
 LT1230H Air Conditioner
 LT1230HR Air Conditioner
 LT1430CR Air Conditioner
Frigidaire LT150EXD2 Wwh(v1) / Tumble Action Washer
Frigidaire LT150EXF2 Wwh(v2) / Tumble Action Washer
Frigidaire LT150EXH2 Wwh(v3) / Tumble Action Washer
Frigidaire LT150EXV2 Wwh(v4) / Tumble Action Washer
Frigidaire LT150EXW2 Wwh(v5) / Tumble Action Washer
Frigidaire LT150JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT150JXF1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150JXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150JXV1 Wwh(v4) / Tumble Action Washer
Frigidaire LT150JXW1 Wwh(v5) / Tumble Action Washer
Frigidaire LT150LXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150LXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150LXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT200PXD2 Wwh(v2) / 27 " Front Load Washer
Frigidaire LT200PXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXW2 Wwh(v1) / 27 " Front Load Washer
Frigidaire LT250EXD2 Wwh(v6) / Tumble Action Washer
Frigidaire LT250EXD4 Wwh(v7) / Tumble Action Washer
Frigidaire LT250EXF2 Wwh(v8) / Tumble Action Washer
Frigidaire LT250EXF4 Wwh(v9) / Tumble Action Washer
Frigidaire LT250EXH2 Wwh(v10) / Tumble Action Washer
Frigidaire LT250EXH4 Wwh(v11) / Tumble Action Washer
Frigidaire LT250EXV2 Wwh(v12) / Tumble Action Washer
Frigidaire LT250EXV4 Wwh(v13) / Tumble Action Washer
Frigidaire LT250EXW2 Wwh(v14) / Tumble Action Washer
Frigidaire LT250EXW4 Wwh(v15) / Tumble Action Washer
Frigidaire LT250JXD1 Wwh(v6) / Tumble Action Washer
Frigidaire LT250JXF1 Wwh(v7) / Tumble Action Washer
Frigidaire LT250JXH1 Wwh(v8) / Tumble Action Washer
Frigidaire LT250JXV1 Wwh(v9) / Tumble Action Washer
Frigidaire LT250JXW1 Wwh(v10) / Tumble Action Washer
Frigidaire LT250LXD1 Wwh(v5) / Tumble Action Washer
Frigidaire LT250LXH1 Wwh(v6) / Tumble Action Washer
Frigidaire LT250LXW1 Wwh(v4) / Tumble Action Washer
Frigidaire LT350RXD1 Wwh(v2) / 27 " Front Load Washer
Frigidaire LT350RXW1 Wwh(v1) / 27 " Front Load Washer
Whirlpool LT4900XMW0 LAUNDRY CENTER
Whirlpool LT4900XMW1 LAUNDRY CENTER
Whirlpool LT4900XMW2 LAUNDRY CENTER
Whirlpool LT4900XSW1 LAUNDRY CENTER
Whirlpool LT4900XSW2 LAUNDRY CENTER
Whirlpool LT4900XSW3 LAUNDRY CENTER
Whirlpool LT4905XMW0 Laundry Centers
Whirlpool LT5000XMW0 LAUNDRY CENTER
Whirlpool LT5000XMW1 LAUNDRY CENTER
Whirlpool LT5000XSW1 LAUNDRY CENTER
Whirlpool LT5000XSW2 LAUNDRY CENTER
Whirlpool LT5000XSW3 LAUNDRY CENTER
Whirlpool LT5000XVW0 LAUNDRY CENTER
Whirlpool LT5004XMW0 LAUNDRY CENTER
Whirlpool LT5004XMW1 LAUNDRY CENTER
Whirlpool LT5004XSW1 LAUNDRY CENTER
Whirlpool LT5004XSW2 LAUNDRY CENTER
Whirlpool LT5004XSW3 LAUNDRY CENTER
Whirlpool LT5004XTW1 LAUNDRY CENTER
Whirlpool LT5004XVW0 LAUNDRY CENTER
Whirlpool LT5005XMW0 LAUNDRY CENTER
Whirlpool LT5009XMW0 LAUNDRY CENTER
Whirlpool LT5100XSW0 Laundry Centers
Whirlpool LT5100XSW1 Laundry Centers
Whirlpool LT5100XVW0 LAUNDRY CENTER
Frigidaire LT600EXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT600EXD4 Wwh(v2) / Tumble Action Washer
Frigidaire LT600EXF1 Wwh(v3) / Tumble Action Washer
Frigidaire LT600EXF4 Wwh(v4) / Tumble Action Washer
Frigidaire LT600EXH1 Wwh(v5) / Tumble Action Washer
Frigidaire LT600EXH4 Wwh(v6) / Tumble Action Washer
Frigidaire LT600EXV1 Wwh(v7) / Tumble Action Washer
Frigidaire LT600EXV4 Wwh(v8) / Tumble Action Washer
Frigidaire LT600EXW1 Wwh(v9) / Tumble Action Washer
Frigidaire LT600EXW4 Wwh(v10) / Tumble Action Washer
Frigidaire LT600JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT600JXF1 Wwh(v2) / Tumble Action Washer
Frigidaire LT600JXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT600JXV1 Wwh(v4) / Tumble Action Washer
Frigidaire LT600JXW1 Wwh(v5) / Tumble Action Washer
Whirlpool LT7000XTW0 LAUNDRY CENTER
Whirlpool LT7000XTW1 LAUNDRY CENTER
Whirlpool LT7000XVW0 Laundry Centers
Whirlpool LT7004XTW0 Laundry Centers
Whirlpool LT7004XTW1 Laundry Centers
Whirlpool LT7004XVW0 Laundry Centers
Frigidaire LT700EXD1 Wwh(v11) / Tumble Action Washer
Frigidaire LT700EXD4 Wwh(v12) / Tumble Action Washer
Frigidaire LT700EXD6 Wwh(v13) / Tumble Action Washer
Frigidaire LT700EXF1 Wwh(v14) / Tumble Action Washer
Frigidaire LT700EXF4 Wwh(v15) / Tumble Action Washer
Frigidaire LT700EXF6 Wwh(v16) / Tumble Action Washer
Frigidaire LT700EXH1 Wwh(v17) / Tumble Action Washer
Frigidaire LT700EXH4 Wwh(v18) / Tumble Action Washer
Frigidaire LT700EXH6 Wwh(v19) / Tumble Action Washer
Frigidaire LT700EXV1 Wwh(v20) / Tumble Action Washer
  #2 (permalink)
Old 06-27-2008, 04:35 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Sounds like a bad timer, just call this parts site for the correct timer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Clothes Wet after spin Jack-99 Washer Repair 0 10-18-2009 09:44 AM
Maytag clothes washer, new pump and belt replaced, clothes wet after spin, further qu yzhong Washer Repair 3 09-22-2009 10:35 AM
Maytag clothes washer, new pump and belt replaced, clothes wet after spin, further qu yzhong Washer Repair 0 08-26-2009 03:18 PM
Maytag clothes washer, new pump and belt replaced, clothes wet after spin, more quest yzhong Washer Repair 1 07-21-2009 03:41 AM
Clothes are wet after spin looking_for_answers Washer Repair 7 03-13-2009 01:37 PM
