| » How to replace front seal on Kenmore washer |
Model Number: Elite He3 Brand: Kenmore Age: 1 - 5 years
My Kenmore Elite washer started leaking and I notied that front seal was shredded. Ordered the part from here, part no. AP3128710 (8181850). Took the shredded seal out and it seemed like it was held in by a clamp. But trying to put new seal on has been a challenge! I am trying to just sort of place it around the border and there is not enough space to make it fit all around. Any easier way to do this or do I need to take apart some more parts? Its the side which faces inside the washer which is tricky. I just can't get it secured tight around the border! Any tricks or ideas?? |
I did this repair 9 months ago. exact steps are a little hazy, however I did it with minimal tear down. access was thru the bottom access cover and door opening. i did remove the 2 screws at bottom of front cover. if memory serves me correct, there is a large hose style clamp on the tub side. and a spring clamp at the door side. i removed the tub side first. really dont remember if i put the tub or the door side on first
remember, that if you have a hard time getting rubber over liped metal, a little dish soap works miracles. good luck |
| Display Modes | |
| Kenmore washer oil leak | bobtx | Washer Repair | 3 | 05-11-2008 07:56 AM |
| front seal bellow on WPL Duet | MGARRETT278 | Washer Repair | 2 | 04-01-2008 05:16 PM |
| can't get washer apart to replace seal | kay | Washer Repair | 4 | 09-05-2007 05:06 PM |
| Kenmore 80-series washer skips spin time | mac | Washer Repair | 1 | 08-14-2007 07:52 PM |
| Maytag Washer Bottom of tub leaking at seal | David S | Washer Repair | 4 | 08-11-2007 12:16 AM |
