Rheinking
#1 Posted : Friday, April 30, 2010 11:19:45 AM(UTC)
Rheinking
After the spin cycle the clothes are still wet (not dripping.) spin cycle works. The wife says she can smell a "burnt plastic" after the spin cycle when the top is open. The washer is 5 years old.
#2 Posted : Friday, April 30, 2010 1:30:18 PM(UTC)
Remove the washer cabinet. Remove the pump and its hoses. Check the pump and hoses for a foreign objects inside.
Check the motor coupling.
- The pump Part number: AP2907492
- The coupling Part number: AP3963893
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 9 time(s).
How to remove the pump.doc (25kb) downloaded 7 time(s).
How to replace the motor drive coupling.doc (25kb) downloaded 8 time(s).
jcrouchtx
#3 Posted : Monday, May 3, 2010 9:38:55 AM(UTC)
jcrouchtx
Appliance repair guy came out and replaced the pump (there were metal shavings everywhere from the old one). That definitely fixed the original problem, but ever since, the clothes are not as dry as they should be at the end of the spin cycle. There is even some water left in the bottom of the tub (Maytag MAV408DAWW rev 10). Any ideas?
#4 Posted : Monday, May 3, 2010 6:00:53 PM(UTC)
I would check the hoses connected to the pump, or even better call this guy back and have him double check what ever he did. I do not think you have to pay him again if it was just recently.
Clothes still wet after spin cycle (Washer Repair)
by gbdad10 3/31/2012 3:35:25 PM(UTC)
