I took apart my maytag neptune and I'm putting it back together and now I find a green plastic line (looks like weed wacker cord) coming from the door latch switch (part #893839) and I don't know where or how to attach the end of it. Please help.
This is an emergency access cord which allows to manually unlatch the door. It goes through the hole on the left and under the dispenser.
Thanks Gene. I thought about it all day and came to that conclusion myself and just put it back together. It all works leak free now. Thanks for you response. I'm sure this will perplex someone else in the future.
You are welcome. I'm glad you were able to fix it.
