| » Washing Machine |
Model Number: LA412 Brand: Maytag Age: More than 10 years
This is a series 2 unit. Serial #335353RP
the machine shakes so bad, that it jumps all over - no matter what size the load is. will u also include a breakdown of how the machine is put together. Ads By Google Related Models |
Quote:
Here is the link to the parts breakdown. Things to look for with the front removed would be the damper pads, which are hard to see. They are located under the pivot point where the tub braces attach to the damper. They are made out of a felt type material. There is also a concrete ring on top of the tub that may be cracked which can cause it to vibrate. The inner tub being loose on the mounting stem can cause a problem also. Look for anything (screws/bolts) that may be loose. http://servicematters.com/maytag_lib...(16001145).pdf The above service manual isn't specifically for your model, but the inner workings that the manual shows is basically the same as yours. Your A412 is an "80's" model so you may want to limit how much you spend on a repair.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Washing machine stops during washing cycle | Puddin1719 | Washer Repair | 4 | 02-06-2011 07:33 AM |
| Washing Machine Stops When Washing | farmallnancy | Washer Repair | 1 | 12-01-2009 05:12 PM |
| Washing machine | DebraT | Washer Repair | 0 | 02-06-2009 10:18 AM |
| washing machine | tiffchocho | Washer Repair | 0 | 03-13-2008 06:55 PM |
| washing machine takes hours to finish washing a load | kelly Monday | Washer Repair | 2 | 09-26-2007 02:42 AM |
