Discuss
Kenmore Elite HE 3t washer Spin/Unbalanced/Leaking problems
 in
Washer Repair
For the last couple of weeks my washer has been unbalanced, loud and moving during the spin cycles. The other
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Elite HE 3t washer Spin/Unbalanced/Leaking problems
  #1 (permalink)
Old 04-27-2010, 08:52 AM
Junior Member
JAPritt is on a distinguished road
Smile Kenmore Elite HE 3t washer Spin/Unbalanced/Leaking problems
Model Number: 11044936201   Brand: Kenmore   Age: 5 - 10 years
For the last couple of weeks my washer has been unbalanced, loud and moving during the spin cycles. The other day my husband took the front panel off and noticed the shocks on the r side in the front and back were unattached so he attached them back.
My washer isn't moving all over the laundry room now, but is still loud and spins like it is unbalanced and leaks water from the center of the bottom of the door down the front.
Last August I had a PM check on the washer and was told "the bearings had some slack in them".
Could someone please help and tell me based on what I have been told and what I am describing if the shocks are bad or the problem is with the bearings or both.
I looked up the schematics of the inside of the washer and I don't even see where the bearings would be located.
I am aware after searching the internet for days of the problems with this washer and the spyder bracket/bearing? Could this be my problem??
I don't want to have to pay someone to come out and look at this if it is going to cost as much or more to repair it as it would to replace it.
Any help would be GREATLY appreciated!!!
Ads By Google
Related Models
Kenmore 11049182992 WASHER
Kenmore 11049722990 AUTOMATIC WASHER
Kenmore 11049722991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049722992 COMPACT WASHER
Kenmore 11051115 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051140 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051309 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051730 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055592 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055593 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055594 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055610 WORM GEAR CASE ASSEMBLY
Kenmore 11055614 WORM GEAR CASE ASSEMBLY
Kenmore 11056171 WORM GEAR CASE ASSEMBLY
Kenmore 11056172 WORM GEAR CASE ASSEMBLY
Kenmore 11056464 WORM GEAR CASE ASSEMBLY
Kenmore 11057624 KENMORE PERMANENT INSTALLATION CONV KIT
Kenmore 11057929 KENMORE DUAL AGITATOR KIT
Kenmore 1105809106 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809500 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809502 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809503 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809702 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809703 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809704 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809800 KENMORE GAS CONBINATION WASHER-DRYER
Kenmore 1105907400 KENMORE GAS DRYER
Kenmore 1105907500 KENMORE GAS DRYER
Kenmore 1105907501 KENMORE GAS DRYER
Kenmore 1105907600 KENMORE GAS DRYER
Kenmore 1105907610 KENMORE GAS-DRYER
Kenmore 1105907700 KENMORE GAS DRYER
Kenmore 1105907710 KENMORE GAS DRYER
Kenmore 1105907720 KENMORE GAS DRYER
Kenmore 1105907721 KENMORE GAS DRYER
Kenmore 1105907730 KENMORE GAS DRYER
Kenmore 1105907800 KENMORE GAS DRYER
Kenmore 1105907801 KENMORE GAS DRYER
Kenmore 1105907802 KENMORE GAS DRYER
Kenmore 1105907950 KENMORE GAS DRYER
Kenmore 1105907951 KENMORE GAS DRYER
Kenmore 1105908000 KENMORE ELECTRIC DRYER
Kenmore 1105908100 KENMORE ELECTRIC DRYER
Kenmore 1105908300 KENMORE ELECTRIC DRYER
Kenmore 1105908400 KENMORE ELECTRIC DRYER
Kenmore 1105908500 KENMORE ELECTRIC DRYER
Kenmore 1105908501 KENMORE ELECTRIC DRYER
Kenmore 1105908600 KENMORE ELECTRIC DRYER
Kenmore 1105908700 KENMORE ELECTRIC DRYER
Kenmore 1105908710 KENMORE ELECTRIC DRYER
Kenmore 1105908711 KENMORE ELECTRIC DRYER
Kenmore 1105908800 KENMORE ELECTRIC DRYER
Kenmore 1105908801 KENMORE ELECTRIC DRYER
Kenmore 1105908810 KENMORE ELECTRIC DRYER
Kenmore 1105908811 KENMORE ELECTRIC DRYER
Kenmore 1105908950 KENMORE ELECTRIC DRYER
Kenmore 1105908951 KENMORE ELECTRIC DRYER
Kenmore 1105908960 KENMORE ELECTRIC DRYER
Kenmore 1105909500 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105909501 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105909502 KENMORE GAS COMBINATON WASHER-DRYER
Kenmore 1105909503 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105917200 KENMORE GAS DRYER
Kenmore 1105917400 KENMORE GAS DRYER
Kenmore 1105917500 KENMORE GAS DRYER
Kenmore 1105917510 KENMORE GAS DRYER
Kenmore 1105917600 KENMORE GAS DRYER
Kenmore 1105917620 KENMORE GAS DRYER
Kenmore 1105917630 KENMORE GAS DRYER
Kenmore 1105918400 KENMORE ELECTRIC DRYER
Kenmore 1105918500 KENMORE ELECTRIC DRYER
Kenmore 1105918600 KENMORE ELECTRIC DRYER
Kenmore 1105918620 KENMORE ELECTRIC DRYER
Kenmore 11060052990 DRYER/WASHER
Kenmore 11060052991 ELECTRIC DRYER
Kenmore 11060056990 ELECTRIC DRYER
Kenmore 11060056991 ELECTRIC DRYER
Kenmore 1106007101 KENMORE GAS DRYER
Kenmore 11060072990 DRYER
Kenmore 11060072991 ELECTRIC DRYER
Kenmore 1106007301 KENMORE GAS DRYER
Kenmore 1106007400 KENMORE GAS DRYER
Kenmore 1106007430 KENMORE GAS DRYER
Kenmore 1106007440 KENMORE GAS DRYER
Kenmore 1106007500 KENMORE GAS DRYER
Kenmore 1106007600 KENMORE GAS DRYER
Kenmore 1106007610 KENMORE GAS DRYER
Kenmore 1106007700 KENMORE GAS DRYER
Kenmore 1106007710 KENMORE GAS DRYER
Kenmore 1106007711 KENMORE GAS DRYER
Kenmore 1106007712 KENMORE GAS DRYER
Kenmore 1106007713 KENMORE GAS DRYER
Kenmore 1106007714 KENMORE GAS DRYER
Kenmore 1106007715 KENMORE GAS DRYER
Kenmore 1106007716 KENMORE GAS DRYER
Kenmore 1106007717 KENMORE GAS DRYER
Kenmore 1106007800 KENMORE GAS DRYER
Kenmore 1106007950 KENMORE GAS DRYER
Kenmore 1106008000 KENMORE ELECTRIC DRYER
Kenmore 1106008100 KENMORE ELECTRIC DRYER
Kenmore 1106008300 KENMORE ELECTRIC DRYER
Kenmore 1106008400 KENMORE ELECTRIC DRYER
Kenmore 1106008430 KENMORE ELECTRIC DRYER
Kenmore 1106008440 KENMORE ELECTRIC DRYER
Kenmore 1106008500 KENMORE ELECTRIC DRYER
Kenmore 1106008600 KENMORE ELECTRIC DRYER
Kenmore 1106008700 KENMORE ELECTRIC DRYER
Kenmore 1106008710 KENMORE ELECTRIC DRYER
Kenmore 1106008711 KENMORE ELECTRIC DRYER
Kenmore 11061062000 DRYER
Kenmore 11061064000 DRYER
Kenmore 11061066000 DRYER
Kenmore 1106107400 KENMORE GAS DRYER
Kenmore 1106107401 KENMORE GAS DRYER
Kenmore 1106107500 KENMORE GAS DRYER
Kenmore 1106107501 KENMORE GAS DRYER
Kenmore 1106107502 KENMORE GAS DRYER
Kenmore 1106107700 KENMORE GAS DRYER
Kenmore 1106107701 KENMORE GAS DRYER
Kenmore 1106107710 KENMORE GAS DRYER
  #2 (permalink)
Old 08-24-2010, 03:59 PM
Junior Member
mabruner is on a distinguished road
Default A simple solution
This is what I did to our Oasis/Kenmore washer. I opened the top and placed 3 high density foam cushions at the front and two sides between the tub and the sides. It may not solve your problem but it is
1 Easy to try
2 cheap
3 it worked for us
I have already replaced the control board, the motor sensors, the harness between the control board & motor sensors including having Sears service make five trips to our house.
  #3 (permalink)
Old 09-19-2010, 05:35 PM
Junior Member
shaestallings is on a distinguished road
Default unbalanced load
our Kenmore Elite has developed the unbalanced load thing in the past couple weeks. Today I took the unit down to the frame. The only thing I found odd was, the basket still had water inside the bottom plastic part and I can not get it to drain out. I wonder why there is water in this part and could this cause the unbalanced issue when in the spin cycle. Good luck with your unit.
  #4 (permalink)
Old 06-26-2011, 11:18 PM
Junior Member
AlDee is on a distinguished road
Default
Quote:
My understanding is the basket is filled with liquid by design.
Though I am having the same problems, noisy, off balance. and it looks like the seal may be leaking.
Has anyone successfully repaired this problem?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Final Spin Problems Jake12 Washer Repair 2 05-11-2011 02:52 AM
Kenmore elite washer is leaking under washer cbs Washer Repair 1 07-12-2009 06:27 PM
Washer becomes unbalanced in spin cycle bswrigh Washer Repair 1 05-13-2009 09:15 AM
Kenmore Elite Washer Leaking Adams1206 Washer Repair 3 04-28-2009 04:53 AM
Kenmore Elite washer spin cycle noise Bikerdav Washer Repair 4 04-27-2009 07:56 PM
