Discuss
motor or control
 in
Washer Repair
Hello, My washer wil fill with water and will attempt to start the agitate cycle. I removed belt and checked
Appliance Repair Forum > Appliance Repair Help > Washer Repair » motor or control
  #1 (permalink)
Old 04-24-2010, 02:52 PM
Junior Member
busch is on a distinguished road
Default motor or control
Model Number: cw600w   Brand: Crosley   Age: 5 - 10 years
Hello,
I removed belt and checked transmision which is fine.
with the belt removed the motor will start then imediately stop.
No contact on the motor ohms to ground all seems fine on it.
Now im familiar with hvac and refrigeration but never have seen much action on washer timers and motors.
The washer will spin out just fine. This does not seem like motor protection causing the issue but i may be wrong. Any help to light my way is greatly apreciated
Ads By Google
Related Models
Crosley CW6500Q WASHER-TOP LOADING
Crosley CW6500W WASHER-TOP LOADING
Amana CW65T MWAVE- CNTRTP / STAND ALONE
Crosley CW7000A WASHER-TOP LOADING
Crosley CW7000Q WASHER-TOP LOADING
Crosley CW7000W WASHER-TOP LOADING
Crosley CW7500Q WASHER-TOP LOADING
Crosley CW7500W WASHER-TOP LOADING
Amana CW76T MWAVE- CNTRTP / STAND ALONE
Crosley CW8000A WASHER-TOP LOADING
Crosley CW8000W WASHER-TOP LOADING
Amana CW8202W2 WASHER-TOP LOADING
Amana CW8203W WASHER-TOP LOADING
Amana CW8203W2 WASHER-TOP LOADING
Amana CW8403W WASHER-TOP LOADING
Amana CW8413W2 WASHER-TOP LOADING
Crosley CW8500W WASHER-TOP LOADING
Amana CW9003 WASHER-TOP LOADING
Amana CW9003W WASHER-TOP LOADING
Amana CW9203W WASHER-TOP LOADING
Amana CW9203W2 WASHER-TOP LOADING
Amana CW9203W3 WASHER-TOP LOADING
Crosley CW9500W WASHER-TOP LOADING
Crosley CW9505W WASHER-TOP LOADING
Maytag CWE1000 WALLOVEN- S/C ELE
Maytag CWE400 WALLOVEN- STD ELE
Maytag CWE401 WALLOVEN- STD ELE
Maytag CWE402 WALLOVEN- STD ELE
Maytag CWE4020ACB WALLOVEN- STD ELE
Maytag CWE4020BCB WALLOVEN- STD ELE
Maytag CWE4100ACB10 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4100ACE10 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4200ACB WALLOVEN- STD ELE
Maytag CWE450 WALLOVEN- STD ELE
Maytag CWE451 WALLOVEN- STD ELE
Maytag CWE470 WALLOVEN- S/C ELE
Maytag CWE4700ACB WALLOVEN- S/C ELE
Maytag CWE4700ACE WALLOVEN- S/C ELE
Maytag CWE4700BCB WALLOVEN- S/C ELE
Maytag CWE4700BCE WALLOVEN- S/C ELE
Maytag CWE4800ACB WALLOVEN- S/C ELE
Maytag CWE4800ACB25 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4800ACE WALLOVEN- S/C ELE
Maytag CWE4800ACE27 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4800ACS WALLOVEN- S/C ELE
Maytag CWE4800ACS14 24" BUILT-IN ELECTRIC OVEN
Maytag CWE500 WALLOVEN- STD ELE
Maytag CWE501 WALLOVEN- STD ELE
Maytag CWE502 WALLOVEN- STD ELE
Maytag CWE5020ACB WALLOVEN- STD ELE
Maytag CWE5020BCB WALLOVEN- STD ELE
Maytag CWE5100ACB10 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5200ACB WALLOVEN- S/C ELE
Maytag CWE550 WALLOVEN- S/C ELE
Maytag CWE5500ACB WALLOVEN- S/C ELE
Maytag CWE5500ACE WALLOVEN- S/C ELE
Maytag CWE5500BCB WALLOVEN- S/C ELE
Maytag CWE5500BCE WALLOVEN- S/C ELE
Maytag CWE5800ACB WALLOVEN- S/C ELE
Maytag CWE5800ACB25 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5800ACE WALLOVEN- S/C ELE
Maytag CWE5800ACE28 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5800ACS WALLOVEN- S/C ELE
Maytag CWE5800ACS14 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE600 WALLOVEN- S/C ELE
Maytag CWE601 WALLOVEN- S/C ELE
Maytag CWE602 WALLOVEN- S/C ELE
Maytag CWE6020ACB WALLOVEN- S/C ELE
Maytag CWE6200ACB WALLOVEN- S/C ELE
Maytag CWE6200ACE WALLOVEN- S/C ELE
Maytag CWE6200ADB WALLOVEN- S/C ELE
Maytag CWE6200ADE WALLOVEN- S/C ELE
Maytag CWE6230ACB WALLOVEN- S/C ELE
Maytag CWE6230ACE WALLOVEN- S/C ELE
Maytag CWE6230ADB WALLOVEN- S/C ELE
Maytag CWE6230ADE WALLOVEN- S/C ELE
Maytag CWE6800ACB WALLOVEN- S/C ELE
Maytag CWE6800ACE WALLOVEN- S/C ELE
Maytag CWE6830ACB WALLOVEN- S/C ELE
Maytag CWE6830ACE WALLOVEN- S/C ELE
Maytag CWE700 WALLOVEN- S/C ELE
Maytag CWE7000ACB WALLOVEN- S/C ELE
Maytag CWE7000ACE WALLOVEN- S/C ELE
Maytag CWE701 WALLOVEN- S/C ELE
Maytag CWE7800ACB WALLOVEN- S/C ELE
Maytag CWE7800ACE WALLOVEN- S/C ELE
Maytag CWE7830ACB WALLOVEN- S/C ELE
Maytag CWE7830ACE WALLOVEN- S/C ELE
Maytag CWE900 WALLOVEN- S/C ELE
Maytag CWE9000ACB WALLOVEN- S/C ELE
Maytag CWE9000ACE WALLOVEN- S/C ELE
Maytag CWE9000BCB WALLOVEN- S/C ELE
Maytag CWE9000BCE WALLOVEN- S/C ELE
Maytag CWE9000BCM WALLOVEN- S/C ELE
Maytag CWE9000BDB WALLOVEN- S/C ELE
Maytag CWE9000BDE WALLOVEN- S/C ELE
Maytag CWE9000CDB WALLOVEN- S/C ELE
Maytag CWE9000CDE WALLOVEN- S/C ELE
Maytag CWE9000DDB WALLOVEN- S/C ELE
Maytag CWE9000DDE WALLOVEN- S/C ELE
Maytag CWE9030BCB WALLOVEN- S/C ELE
Maytag CWE9030BCE WALLOVEN- S/C ELE
Maytag CWE9030BDB WALLOVEN- S/C ELE
Maytag CWE9030BDE WALLOVEN- S/C ELE
Maytag CWE9030DDB WALLOVEN- S/C ELE
Maytag CWE9030DDE WALLOVEN- S/C ELE
Maytag CWE9900 WALLOVEN- S/C ELE
Admiral CWEA100ACB WALLOVEN- STD ELE
White Westinghouse CWEF309ES1 White Westinghouse/electric Range
White Westinghouse CWEF310ES1 White Westinghouse Canada/electric Range
  #2 (permalink)
Old 04-28-2010, 11:23 AM
Junior Member
Default
allright i found that the motor is going out on overload protection in delicate cycle but will agitate on other cycles. i suspect the timer control.
  #3 (permalink)
Old 04-28-2010, 03:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
This is a two speed motor and, more likely, the problem is a bad low speed motor winding.
- The motor Part number: AP4024680
Here are the breakdown diagrams and Replacement parts for CROSLEY CW6000W Washer - Top Loading | AppliancePartsPros.com
P.S. I'm assuming you missed one zero in the model number.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
« washer | Need Help »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing motor control assembly cbrickley Washer Repair 3 04-26-2009 06:57 PM
Frontload Washer - motor or motor control problem? chris-clarke Washer Repair 3 04-06-2009 10:12 AM
Motor/Motor Control Unit Day Washer Repair 0 12-26-2008 01:53 PM
burned motor control board jnhb Washer Repair 1 07-15-2008 03:18 AM
Neptune-Need motor control + ? Tracy CA Washer Repair 5 05-08-2008 03:34 PM
