rossa
#1 Posted : Saturday, June 21, 2008 10:34:23 PM(UTC)
rossa
Our Maytag washing machine will not always fill on it's own (it sometimes does). If we manually fill it with a bucket it goes through the rest of its cycle OK although it also sometimes stops filling on the rinse cycle and has to be once again manually filled with a bucket. Which part needs replacing?
#2 Posted : Sunday, June 22, 2008 9:05:26 AM(UTC)
Probably a bad timer. I would pull the cover off it and spray the contacts with a non-residue cleaning spray while turning the timer shaft.
If this fails, you probably need to order a new timer.
okbobcats
#3 Posted : Tuesday, June 24, 2008 3:58:31 AM(UTC)
okbobcats
I would check to see if your getting power to your water valve.
