Hello and thank for any help in advance.
Our washer just started acting weird. It was running a cycle and jusr froze up at the final spin place and would go no futher. If you moved the switch around you can hear it make some buzzing type sounds until you cut it off. We tried another load and it did the same. Then we tried another load the next day and now it will only fill up and then freezes right there. If i move the switch to other places it does nothing but the buzzing sound unless i get to the place on the dial where it emptys the water which it will do just fine but will not stop. Any suggestions?
