| » Whirlpool Washer won't spin/drain. |
Model Number: LA5705XKW0 Brand: Whirlpool Age: More than 10 years
The washer works on all modes and automatically advances through each cycle. However, when it reaches the spin cycle on any mode the basin stops. The pulleys and belt spin as if it were working but the basin does not and the washer will not drain. I had an issue with the Wig-Wag before but have checked it and that appears to be fine. Since this washer is so old, I don't want to dump hundreds into it's repair but if it is a simple inexpensive fix I would like to try it.
Any suggestions? Ads By Google Related Models |
My guess would be a bad pump or the belt broke on the pulley. If it has belts then it really old so maybe it is time for a new one. I'm thinking it won't try to spin until the water level goes down. If you want to replace the pump you'll have to get the water out. Click on your model number in your post and you'll get a schematic of your washer and the parts list. Call and get prices before you give it a try to see if it's worth it. A washer that old may not be worth it.
| Display Modes | |
| whirlpool washer will not drain or spin | llbishop7@cs.com | Washer Repair | 3 | 08-17-2012 03:24 PM |
| Whirlpool washer won't drain or spin | KellaC32 | Washer Repair | 3 | 12-02-2009 10:37 AM |
| whirlpool duet washer will not drain and spin | bcanebres | Washer Repair | 0 | 11-25-2009 07:57 AM |
| Whirlpool washer won't spin or drain | Jon B | Washer Repair | 1 | 10-09-2009 09:27 AM |
| Whirlpool washer will not drain or spin. Is it the lid switch? | conramana | Washer Repair | 2 | 06-11-2009 08:55 PM |
