lobsterlady
#1 Posted : Wednesday, June 18, 2008 6:27:58 PM(UTC)
lobsterlady
My Maytag washer fills, agitates, spins, refills for rinse cycle then stops. At times I can get it to spin out rinse water by turning knob around to "Spin" on same cycle, at other times I can only get it to spin by changing the cycle from Regular to Wrinkle Free. Is this a timer problem?
#2 Posted : Thursday, June 19, 2008 5:31:44 PM(UTC)
If you have to play with the timer to have your washer finish a cycle then, most likely, the problem is a bad timer.
- The part number for the timer is AP3451716
lobsterlady
#3 Posted : Friday, June 20, 2008 8:02:10 AM(UTC)
lobsterlady
Gene, Thanks for your help. That's what I thought it must be but everything I read said that the timer almost never is the problem.
#4 Posted : Friday, June 20, 2008 10:15:37 AM(UTC)
Keep us posted.
